Carpenter/fencing
No Vent Or Wet Vent ?
The picture is a 3" pvc pipe directly from the first floor toilet, about 12-14" from the cleanout on that 3" line is the shower line on a Y ,is this considered the vent? I'm involve in other things at this house and just happen to look at the plumbing work, the toilet has clogged up a few times and i'm assuming if this shower Y is being used as a wet vent, its too far away.
I'm by far no expert on plumbing but it don't look right to me.
Learning without thought is labor lost; thought without learning is perilous. |
The Grand Wazoo
Re: No Vent Or Wet Vent ?
It's not vented.
FT.WORTH,TX MASTER PLUMB
Trade: plumbing
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx |
Carpenter/fencing
Thanks Killer,Thats what i thought. I guess it will have to be corrected soon ,i don't want to see the toilet overflow and damage the new ceilings I'm about to install in the basement.
He told me he had this done around 2 years ago and the toilet has been stopping up on occasion ever since. This doesn't look like an easy fix, the bay its in is only about 6-7" wide, If i could fit a 3x3x2 Y closer to the 90,there's vent access one bay over, its tighter than a bulls azz, need room to turn the Y up some. Stuck between a joist and a hard place.
Learning without thought is labor lost; thought without learning is perilous. Last edited by nywoodwizard; 01-11-2008 at 09:38 PM. |
#5 | |
The Grand Wazoo
Re: No Vent Or Wet Vent ?Quote:
#6 | |
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
Tin Cup |
#7 | |
Carpenter/fencing
#8 | |
Carpenter/fencing
I just assumed a wye would be less prone to catching waste in the event it can't be turned up enought.
#9 | |
Trade: Professional Homebuilder, Plumber and Electrician---IRC Combination Code Inspector
According to exception for Section P3105.1, Vents for toilets are unlimited in the distance they are required to be from them. Simply put: there is no limiting distance that a toilet is required to be from any vent that aerates it. Any vent on the plumbing system, generally speaking, that is at least 1 1/2", is an adequate vent for any toilet on the system. Problem here is that what you have is a 'wet vent' And since it appears to be a horizontal wet vent (that is, the venting is all occuring on the same horizonatl branch), there is no need for additional venting, and this is a perfectly legal installation. If there is chronic 'stopping' of this toilet, look for other cause than inadequate venting...like too much paper...use of wipes that won't dissolve when wet...or other causes. Inadequate venting is unlikley the cause. |
| seal gable vents after ridge vent installed? | tacoma5050 | Roofing | 26 | 01-18-2008 10:50 PM |
| Ridge vent issues? | apkole | Roofing | 4 | 05-08-2007 06:46 PM |
| New Ridge Vent Installed Correctly? | itwerx2 | Roofing | 6 | 04-01-2007 04:38 PM |
| Dryer vent question | hanover | Plumbing | 12 | 11-15-2006 09:01 PM |
| Plumbing vent issue | Knyte260 | Plumbing | 3 | 03-21-2006 07:24 AM |
