No Air Gap For Dishwasher
Old 11-13-2006, 12:14 PM   #1
robertc65's Avatar
Trade: Former Electrician
I was helping a friend remove an old countertop yesterday in preperation for a new counter top and sink install in a few days. We got to talking and he told me that the counter people told him he did not need a whole drilled for the air gap. They told him he did not need an air gap. Is this true? I have only hooked up a few dishwashers in my day, but I have always used an air gap. I'm thinking that without one, water could backup into the sink when the dishwasher drains. What's the real deal with not having a air gap?
Thanks
Rob
robertc65 is offline
Old 11-13-2006, 01:39 PM   #2
HOT... Smells like Money!
talos4's Avatar
Trade: commercial roofing
Re: No Air Gap For Dishwasher
I'm not an expert and probably full of hot air but,
I installed a new dishwasher in my kitchen where one had not been before. My cast iron sink was relatively new with no hole for an airgap.
A plumbing friend of mine suggested the following:
When running the drain line loop the drain line inside the cabinet before connecting it to the drain pipe. Making sure the loop is up as opposed to hanging down. The loop in mine is about 16" in diameter.
Works fine, have had zero problems with the dishwasher draining or any water backing up onto the sink.
talos4 is offline
Old 11-13-2006, 02:55 PM   #3
robertc65's Avatar
Thanks for shared your experience. I wonder if the loop servers to slow down the water a bit.
Rob
Old 11-13-2006, 04:59 PM   #4
dkillianjr's Avatar
Ive ran into this a bunch, Ive probly installed about 15 or so dishwashers with the loop this way, some of them years ago and no problems at. some of the dishwashers even have the drain preloped on the side of the unit.
dkillianjr is online now
Old 11-13-2006, 07:03 PM   #5
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Not required here, drain hose only needs to be secured higher then the bottom or sink, airgaps look like crap anyways.
Ron The Plumber is offline
Old 11-13-2006, 07:16 PM   #6
Plumber
tzzzz216's Avatar
Trade: Plumbing
I agree with you Ron , they've been doing that way for years .
tzzzz216 is offline
Old 11-13-2006, 08:45 PM   #7
mickeyco's Avatar
Trade: Squirrel Handler
I've installed a few hundred + dishwashers and very few with air gaps, in the City of Chicago it is/was a requirement but we never installed one (eliminated quite a few), only hooked up existing ones. The IPC requires them, the UPC does not and I don't know about the Illinois plumbing code. Way to many codes relating to this. The purpose of the air gap is too prevent back-flow and siphoning, and newer dishwashers (past 20 + years) have back flow preventers built in and looping the drain hose (not a circle, but an upside down u to the top of the cabinet or behind/side of dishwasher) prevents siphoning. Aside form being ugly space wasters the cheap air gaps have a tendency to spit and cough water out.
mickeyco is offline
The Following User Says Thank You to mickeyco For This Useful Post:
skyhook (07-12-2009)
Old 11-14-2006, 12:59 PM   #8
robertc65's Avatar
Thanks for the responses. I'll tell him not to worry with the air gap. The hose from the dishwasher has plenty of slack so we can do the upside down U. Should the hose including the U stay below the bottom of the sink drain?
Thanks
Rob
Old 11-14-2006, 03:19 PM   #9
Pro Plumber
Trade: Plumber
As long as the hose is secured higher then bottom of sink, it don't matter
The Following User Says Thank You to Ron The Plumber For This Useful Post:
Old 11-14-2006, 03:23 PM   #10
robertc65's Avatar
Sounds Good.
Thanks again
Rob
Old 07-07-2009, 04:06 AM   #11
emailyoungsoo's Avatar
Trade: general contractor
I was at a job today where the home owner purchased a new Whirpool DW that had a drain hose already high looped on the side of it. Does this mean I don't need to high loop again before i connect to the disposal? Is is bad if I double high loop the drain?
Thanks-
emailyoungsoo is offline
Old 07-07-2009, 09:06 AM   #12
Resident Lurker
LJSMITH1's Avatar
Trade: Electrical Products Manufacturer
What does the manufacturer's instructions say? Follow them.
LJSMITH1 is offline
Old 07-07-2009, 09:24 AM   #13
Pro Plumber
Trade: Plumber
What does your code say, code tells you how the drain is to connect to the waste.
Old 07-11-2009, 07:12 PM   #14
mccarty.74's Avatar
Trade: framer
No, even with the side loop you still need an air gap. It is the opposite of that, it is so a backed up sink does not follow into the dishwasher. I'm not a plumber but for this type of question visit www.plbg.com. Ask for HJ, Redwood, dlh, or packy. As far as plumbing goes you will not find a more definitive answer and those guys are infallible.
What would you say...ya do here?
mccarty.74 is offline
Old 07-12-2009, 10:42 AM   #15
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
that is an incorrect statement.
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
The Following User Says Thank You to Proud Plumber For This Useful Post:
Ron The Plumber (07-12-2009)
Old 07-12-2009, 11:02 AM   #16
solar guy
naptown CR's Avatar
Trade: solar contracting
Air gaps haven't been required here in years and I refuse to install one. Te purpose was to prevent a cross connection between the water supply and the waste. On the old dishwashers the supply line entered the dishwasher below the flooe level rim or in plain english the botom lip of the door. The new ones now fill from about 4 inches up on the side therefore creating an air gap within the dishwasher.
naptown CR is offline
The Following 2 Users Say Thank You to naptown CR For This Useful Post:
Proud Plumber (07-12-2009), skyhook (07-12-2009)
Old 07-12-2009, 11:11 AM   #17
Professional Instigator
rbsremodeling's Avatar
Been reading the directions on stuff again I see
rbsremodeling is offline
Old 07-16-2009, 06:07 PM   #18
catspaw's Avatar
Trade: building
real men don't read directions they just do it. the uniform plumbing code still requires an air gap if that is your code of choice. the international plumbing code does not require an air gap. high loop or per manufacturers installation instructions.
catspaw is offline
Old 07-16-2009, 06:33 PM   #19
Pro Plumber
Trade: Plumber
Originally Posted by catspaw View Post
the uniform plumbing code still requires an air gap if that is your code of choice..
I so glad you told me what my code is, ever think about getting the a new code?
Old 07-16-2009, 06:41 PM   #20
solar guy
naptown CR's Avatar
yeah I'm a dweeb like that
