New Water Heater Pounding Puffing Sound
Old 12-24-2017, 04:04 PM   #21
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,364
Re: New Water Heater Pounding Puffing Sound
The vent is real nice.
Warner Mill Works
WarnerConstInc. is online now
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task!
Old 12-25-2017, 03:49 PM   #22
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,919
Your anti-hammer valves might be acting as simple harmonic system and vibrating when the water flows....
I'd try and eliminate the "traps" in the flex tubing that might collect steam/air pockets.
Did the hot air rotater( a drop in piece of twisted sheet metal) in the internal heater chimney get removed accidentally... or is the gas burner out of level too close to the tank? ( some are by design on self cleaning models)
And fix the chimney or buy a Carbon monoxide detector and CO2 gas detector....
Your anti-hammer devices need to be closer the valves they protect....
And if you have a back flow preventer on your water service, you need an expansion tank for max fixture and heater life cycles.
Last edited by Fouthgeneration; 12-25-2017 at 04:07 PM. Reason: Anti- hammer valve reading
Fouthgeneration is online now
Old 12-26-2017, 05:47 AM   #23
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 4,506
I'd try it without the anti-hammer valves, but no shutoff? Is that a 1/2" supply line?
RangoWA is online now
Old 12-26-2017, 09:14 PM   #24
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,788
I'm pretty sure codes here in my part of CO call for a shut off on the cold side but not on the hot.
But heck I don't see any shut off valves on either line in the pics and that vent is all friggin wonky.
As far as your noise goes ? Call a plumber. It's probably a bad Flanuten valve. I've seen a few Klonker valves go bad too... but thats rare.
kirkdc is offline
Old 12-27-2017, 10:49 AM   #25
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 333
Could also be the muffler bearings or the johnson rods, just spitballin' though.....
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
kirkdc (12-27-2017)
Old 12-27-2017, 08:03 PM   #26
cvtsf's Avatar
Rewards Points: 180
Originally Posted by Accent View Post
Since I am obviously not getting any helpfull advice from this online community I will delete my account so as not to further offend you all.
OK, so you guys weren't very nice but really "i'm gonna take my ball and go home?'
cvtsf is offline
Old 12-27-2017, 08:06 PM   #27
cvtsf's Avatar
Rewards Points: 180
Back to the original problem:
Around here, you never put a shutoff on the hot side only the cold side
Also, I've never seen hammer arrestors on a water heater? Certainly not the internal bladder type. I've only seen those used on washing machines and ice makers because the water pulses on and off rapidly.
cvtsf is offline
trouble shooting water heater Tom M Plumbing 9 02-14-2016 09:12 AM
water heater boiler Dr Heat HVAC 4 12-15-2010 11:24 AM
Replacing my water heater Tahoe Builder HVAC 1 12-08-2010 05:21 PM
At we cater exlusivly to professional contractors who make their living as a contractor. Knowing that many homeowners and DIYers are looking for a community to call home, we've created DIY Chatroom is full of helpful advices and perfect for DIY homeowners.
