New Water Heater Pounding Puffing Sound - Plumbing - Contractor Talk
Old 12-22-2017, 05:25 PM   #1
Accent's Avatar
Trade: Tile/Hard Surface Flooring
I just replaced my 50 gal Natural Gas water heater with pretty much the exact same unit. When I run water it is making a pounding/puffing noise coming from the water heater. Almost sounds like a train chugging along. What did I do wrong?
Accent is offline
Old 12-22-2017, 10:03 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,880
Re: New Water Heater Pounding Puffing Sound
It will go away in a few days.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
SmallTownGuy (12-23-2017)
Old 12-22-2017, 10:54 PM   #3
Accent's Avatar
Really so just use water as usual?
Accent is offline
Old 12-23-2017, 10:34 AM   #4
Accent's Avatar
The knocking sound is quite loud. I noticed the copper hose is a little narrow in a spot because of the angle to screw it on the water heater. The new water heater is about an inch taller than the old one. Could that be the issue?
Accent is offline
Old 12-23-2017, 01:36 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,855
Did you reverse the hook ups? cold in the out port and vice versa? Missing "drop" pipe in cold port?
Over pressure, install gauge on draincock or line. Maybe needs a expansion tank if you have a anti back flow water service....
Fouthgeneration is offline
Old 12-23-2017, 01:46 PM   #6
Accent's Avatar
No the hook ups are correct. Don't think I was supposed to put anything in cold port. Here is a picture of my not very good work. What do you think?
New Water Heater Pounding Puffing Sound-photo_20171223_124234_1514054759341.jpg
Accent is offline
Old 12-23-2017, 01:47 PM   #7
Accent's Avatar
Another pic
New Water Heater Pounding Puffing Sound-photo_20171223_124141_1514054852113.jpg
Accent is offline
Old 12-23-2017, 01:49 PM   #8
Accent's Avatar
I'm trying to reach an actual plumber I know to come take a look but may not be able to until after holiday so hoping I can get some help on here until then.
Accent is offline
Old 12-23-2017, 04:26 PM   #9
The Grand Wazoo
The sound is caused by the air that got trapped in the house piping as it was being displaced by the water when you filled the new tank. It will work itself out of the system in a matter of a few days.
Old 12-23-2017, 05:02 PM   #10
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 630
What's up with that vent, Hoss?
Delta
Old 12-23-2017, 11:02 PM   #11
Accent's Avatar
Delta
I know it looks bad because the new water heater was a little taller so it didn't fit and I was being lazy. I will fix it if you think it will cause any issue. ?
Accent is offline
Old 12-23-2017, 11:30 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,625
Seriously? That's a life issue, man. Do it right; don't expect a free do-over.
Tinstaafl is offline
Old 12-24-2017, 12:05 AM   #13
avenge's Avatar
Rewards Points: 3,140
I'm assuming you don't know the function of the vent? I would hire a plumber asap.
avenge is offline
Old 12-24-2017, 09:34 AM   #14
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 569
No shut-off valve on the hot side?
rescraft is offline
Old 12-24-2017, 10:02 AM   #15
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,694
Originally Posted by seven-delta-fortyone View Post
what's up with that vent, hoss?
Delta
diy
Big Johnson is online now
Old 12-24-2017, 01:55 PM   #16
Accent's Avatar
Actually I'm a woman "man" but thanks for the advice. Very helpful.
Accent is offline
Old 12-24-2017, 01:58 PM   #17
Accent's Avatar
There is no shut off valve on the hot side. I've now noticed it is only happening when we flush the toilets not when running shower or anything else.
Accent is offline
Old 12-24-2017, 03:20 PM   #18
avenge's Avatar
Is that your excuse for being lazy and doing a half ass job?
avenge is offline
Old 12-24-2017, 04:08 PM   #19
Accent's Avatar
I signed on here hoping for some helpful advice. I am not a plumber, I am a flooring contractor. I would have GLADLY hired a plumber if I could have afforded the price quoted. Just like in my business I have seen people DIY the work and it usually doesn't look close to as good or correct sometimes and that is understandable. My dryer also broke last week and I am fixing that instead of taking it to a professional. We used to live in a country where people did things for themselves and the wealthy could hire specialists/plumbers to come in and do the work for them. Now everybody expects to hire sombody for everything. Since I am obviously not getting any helpfull advice from this online community I will delete my account so as not to further offend you all.
Accent is offline
Old 12-24-2017, 04:38 PM   #20
avenge's Avatar
There's nothing wrong with diy if it's done correctly, when it becomes a safety issue you better figure out how to do it right or hire someone. The word "man" used by Tinstaafl wasn't meant as a male.
You received opinions on what the issue might be but when you posted a pic comments were made on your crappy unsafe diy job assuming because you were lazy. Do you work that way on your flooring jobs also?
avenge is offline
trouble shooting water heater Tom M Plumbing 9 02-14-2016 10:12 AM
water heater boiler Dr Heat HVAC 4 12-15-2010 12:24 PM
Replacing my water heater Tahoe Builder HVAC 1 12-08-2010 06:21 PM
