Need Help Identifying Torch Piece
Old 02-10-2010, 09:09 PM   #1
swp4lfe's Avatar
Trade: Union Carpenter
Hello I am re-modeling my house and i am currently working on my new bathroom and soldering copper pipes. Now i am burning mapp gas and my torch head keeps getting dirty/clogged. I was wondering what the piece is called that screws on/off of the torch. Its the "head" piece where the flame comes out and has little pin holes around it for air. I need to get a new piece but i cant find it anywhere and i was hoping if i knew what the piece is actually called i can do more research and find it possibly. I bought the whole torch head for a doller back in the day and i dont want to buy a new one if only the head is clogged. I tried cleaning it but it seams like the pipe is not getting hot enough now and i dont know what else could be the problem.
Any info on the piece or where to buy one will be great. Thanks!
swp4lfe is offline
Old 02-10-2010, 09:31 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Need Help Identifying Torch Piece
It's a thingamabob, but you need to know what brand thingamabob to try and get parts.
KillerToiletSpider is offline
Old 02-10-2010, 09:51 PM   #3
BCConstruction's Avatar
Trade: Construction
What brand is it? I guess your talking about the nozzle?
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 02-10-2010, 09:58 PM   #4
SEMI RETIRED
griz's Avatar
I put a new frankel bearing in mine and it works just swell
Ok, is the torch made for MAPP gas? Try cleaning the tip, bunch of little holes in a circle. They make a tip cleaner, looks like a bunch of thin and thinner halves of straightened paper clips. The top of your torch, tip section, should unscrew. And after all this you just might need a new torch.
griz is offline
Old 02-13-2010, 06:48 PM   #5
swp4lfe's Avatar
yeah i cleaned out all the holes real good over these past days stuck inside because of the "blizzard" over here in philadelphia area. Im not sure of the brand i have to look for some markings to identify it. But thanks for the help.
swp4lfe is offline
torch down nails pulling out seattlealex Roofing 22 09-01-2010 10:22 AM
LowBoy Toilets (One Piece Toilet) johndaprano Plumbing 2 01-30-2010 09:24 AM
Favorite torch down material roof-lover Roofing 26 02-25-2009 10:08 AM
Torch Down Roofing steveoboist Roofing 14 09-06-2008 12:26 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
