Need Help On Fire Pit
Old 07-16-2007, 07:24 PM   #1
ronald owen jr's Avatar
Trade: general contractor landscape contractor
Can I run a 24" fire ring on a 3/4" pipe for 60 feet?
I live in california and the city code is really ambiguous.
Please help.
Thanks, Ron
ronald owen jr is offline
Old 07-16-2007, 11:31 PM   #2
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Re: Need Help On Fire Pit
You would really have to measure the total length from the meter and see a schematic of the piping that is currently there and then look at a National Fuel Gas Code book to answer the question.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 07-16-2007, 11:59 PM   #3
JamesNLA's Avatar
Trade: Plumbing & Electrical
Please help.
Thanks, Ron
You want to draw about 30K btu's from the system. You need to size the system. Find out what you would be doing to the rest of the appliances.
If you are GOING to add it regardless......for that distance run, see if you can pick it up at a 1" fitting. But then again, it's not that big of a draw.
Code says you must deliver the correct amount of WC. In order to do that, ya need to size the house properly
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 07-17-2007, 02:41 AM   #4
The gas line was plumbed in by the home builder. I have a 3/4" stub-out that I need to connect to. Can I run a 24" fire ring on a line that is 60 feet long?
Thanks, Ron
Old 07-17-2007, 11:45 AM   #5
JamesNLA's Avatar
Bud, you can run it as long as you like. You can run it to your neighbors house and run his fire pit too.....I aswell as DVR was simply telling you h0ow to do it properly. I personally think you should hire a plumber, it's obvious this is not your day job.........
-Adrock
JamesNLA is offline
Old 07-18-2007, 12:40 PM   #6
Grumpyplumber's Avatar
Trade: Plumber
I could not possibly agree more.
Drainage, water, venting...sure maybe.
Gas..NO!
Imagine a slow leak underground that seeps through the neighborhood.
Grumpyplumber is offline
Old 07-18-2007, 01:07 PM   #7
Dustball's Avatar
Gas..NO!
Happened nearby nine years ago-
http://en.wikipedia.org/wiki/1998_St._Cloud_explosion
Dustball is offline
Concrete fire pit ronald owen jr Masonry 14 08-07-2007 10:24 PM
Fire Place Miller Painting & Finish Work 15 04-21-2007 07:37 AM
Fire Escapes skylands Construction 4 03-09-2007 08:22 PM
fire box construction ELM Masonry 8 02-01-2007 01:08 PM
fire door mechanism 72chevy4x4 Electrical 4 01-11-2007 09:38 AM
