Navien Tankless
Old 09-13-2009, 12:14 PM   #1
kane co plumber's Avatar
Trade: Plumber
Navien Tankless
Recently a rep has been pushing the Navien 98% efficient tankless with two stainless stell heat exchangers the lower of the two being condensing. The larger residential model the 240a puts out an impressive 7.2? gpm at 70 degrees of rise(not sure if that is exact but from what I recall if thats not it, its pretty close). Also comes with built in recirc pump and buffer tank. Supposedly with the recirc pump you can install grundfos comfort blocks under lavs and use the cold as a return. If any of you have installed this unit and know if in fact the recirc works with grundfos blocks I would greatly appreciate your feed back and experience with the units.
kane co plumber is offline
Navien tankless westernhvac HVAC 0 03-24-2009 10:49 PM
tankless water heater p1grinder Plumbing 17 02-20-2009 10:08 PM
Tankless hot water systems Custom Renos HVAC 9 02-07-2009 02:41 PM
indirect water heater v.s. tankless world llc Plumbing 31 02-02-2009 11:28 AM
problems with Rheem tankless hot water heater configuration? KesslerDweller Plumbing 22 05-14-2008 12:35 AM
