Moving Toilet Location In A Slab
Old 03-20-2011, 11:49 AM   #1
NorCalBuilder's Avatar
Trade: B Class General Contractor
Can anyone tell me about potential problems joining ABS plastic waste line to a cast iron waste line under a concrete slab?
NorCalBuilder is offline
Old 03-20-2011, 12:34 PM   #2
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Re: Moving Toilet Location In A Slab
What exactly do you want to know?
MAULEMALL is offline
Old 03-20-2011, 01:10 PM   #3
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Lightbulb
The potential problem I envision is leaking through the ABS to CI connection.
A rubber no-hub connector is a possibility,
make sure it's installed properly.
Also if the cast iron is already leaking, and you attach to it, you own it.
btw, * Welcome to CT *
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
NorCalBuilder (03-20-2011)
Old 03-20-2011, 10:40 PM   #4
I have always used no hub connectors when switching from cast Iron to ABS above grade, but specificly was wondering about the longevity of the rubber and more specificey the metal bands that create the seal if they were to be burried in concrete. Is this a bad idea? Any insights would be helpful.
Old 03-20-2011, 10:55 PM   #5
I know you can use a rubber no hub coupling, but I am not sure if pouring concrete around the junction in an ok thing to do. I am moving a toilet about 12" and the existing waste line is cast iron buried under the slab. I don't know if there is enough fall to allow me to set the junction in the dirt under the concrete repair, but the concern is kind of the same. Is the rubber going to fail down the road or more specifically, are the metal straps that create the seal going to rust out and leak? Any insights would be helpful.
Thanks,
Tony
Old 03-20-2011, 11:00 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 468
Hey Tony, No hub coupling is pretty standard method.
If you have other issues or concerns call a plumber.
griz is offline
NorCalBuilder (03-21-2011)
Old 03-20-2011, 11:36 PM   #7
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
It will be just fine
see ya!
Mike's Plumbing is offline
The Following User Says Thank You to Mike's Plumbing For This Useful Post:
Old 03-20-2011, 11:49 PM   #8
MikeGC's Avatar
Trade: All construction, remodeling, home improvements
Location: Rochester, NY Elmira, NY, WNY, Finger Lakes, Southern Tier
Rewards Points: 510
Its not an issue. Go for it
MikeGC is offline
The Following User Says Thank You to MikeGC For This Useful Post:
Old 03-21-2011, 09:20 AM   #9
Talking
Thank you for the post guys, today I get to cut out the concrete....and use my new bosh 11316EVS SDS-max Demolition Hammer! I will post how effective the tool is. THANKS again
Old 03-21-2011, 12:33 PM   #10
katoman's Avatar
Trade: carpenter
Just wrap the connection with tar paper so the concrete won't actually make contact with the metal strap and rubber.
katoman is offline
The Following 2 Users Say Thank You to katoman For This Useful Post:
kcremodeling (03-27-2011), NorCalBuilder (03-21-2011)
Old 03-21-2011, 10:04 PM   #11
That is a really good idea. Thanks.
Old 03-27-2011, 07:44 AM   #12
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
we do that in FLORIDA ALOT.....but what i do when filling in the hole. Is take pea gravel and pour it on top of the connection . Then fill with dirt no rocks and just pour concrete over that...
Thats how i do them maybe I am crazy
opiethetileman is offline
Old 03-27-2011, 08:00 PM   #13
kcremodeling's Avatar
Trade: Licensed Contractor
We do it all the time.
kcremodeling is offline
Toilet Flange HandyHails Tiling 19 11-24-2015 09:58 PM
How to get toilet level on ungauged slate? ApprenticeGal Tiling 25 12-30-2009 02:38 PM
Flagstone over slab paulbronson Flooring 2 10-26-2009 07:15 PM
waterproofing the parking deck slab paulbronson General Discussion 1 10-23-2009 02:47 PM
Toilet install Jjheezy Plumbing 6 04-03-2009 08:52 AM
