Most Efficient Cost Effective Radiant Floor Setup
Old 05-18-2009, 12:55 PM   #1
Morning Wood's Avatar
Trade: Pretty much anything with wood
Haven't asked my plumber yet, but anyone have opinions on which radiant systems are the most efficient, but also won't kill in the installation process. Basically the two I am comparing are staple up underneath the subfloor and some type of screw down panels on top of the subfloor. Hardwood floor over most of the radiant. Pros I can think of. staple up probably cheaper, but I don't know if it runs as efficiently. using panels is more pricey but may allow a lower water temp. Drain back system with no glycol anywhere. Thanks, nick.
Morning Wood is offline
Old 05-18-2009, 02:32 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Most Efficient Cost Effective Radiant Floor Setup
This sounds like a solar application yes?
naptown CR is offline
Old 05-18-2009, 09:03 PM   #3
No no. I don't know what the hell I was thinking when I typed that. It isn't a solar system. forget I said drainback. It just won't have glycol in the system.
Old 05-18-2009, 09:09 PM   #4
genecarp's Avatar
I dont think under the subfloor can compare to a topside installation, check out STADLER i used this system under hardwood a few years ago, nice stuff to work with G.
genecarp is offline
Old 05-18-2009, 09:14 PM   #5
genecarp's Avatar
Here is the stuff i use
http://www.boucherenergy.com/pdf/JLC.pdf
genecarp is offline
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 07:52 PM
cost plus % contract chaney Business 10 03-17-2009 03:58 PM
Cost Effective Design Amp General Discussion 3 11-04-2006 07:31 PM
