General Contractor
Trade: Multifamily Maintenance/Remodel
More... Which Caulk?
It looks like this issue gets touched on from time to time, so sorry if I am beating a dead horse.
I oversee several apartment complexes, most of which have their own on-site handymen. Many of these units have water damage, sometimes it is because the caulking has failed in the shower enclosures. In my projects I use silicone ll or sometimes dap kit & bath. I have noticed most of these handymen "kings of hd supply" are using polyseamseal. Should I discourage them from using the less expensive product? Are we both using junk? One of my plumbing supply stores has Harvey's - anyone like that? Is the dap at the box stores a retail version? - lesser quality then same brand at pro suppliers? What is your preference? What's the best that money can buy? - dow corning? Thanks |
#2 | |
Re: More... Which Caulk?Quote:
or if you aren't making a clean three sided mechanical joint, good luck. PolySeamSeal Tub and Tile is the best I have found in over thirty years. My tub is still in excellent shape after 10 years. Most of the problems I see are from guys who try and paint it over a poorly prepared joint.
I like Green things
The stuff from Dupont is the bomb, too bad one tube is almost 30 bucks.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Trade: Perfessional Contracter
Cheap POLYSEAMSEAL here. I learned about it from a union mason nine years ago, and my tile guy uses it too. Happy happy happy.
#5 | |
right?
I like Green things
It comes in any color you want, well a lot of colors.
I started using it on solid surface material and it preformed so well I use it anywhere caulk is required in a bath or kitchen. The little tubes that match SS colors are like 40 bucks and I think they are 8oz.
Trade: Construction
I have had very good luck with Dow Corning 785 it's all we used in the UK and never had issues with it once. I used up the last tube i bought to the US with me a few weeks ago and aint looked for it in the US yet but i have been using the GE stuff and Polyseamseal and to be honest they dont seem any different. Only time will tell. The most important thing to do is make sure you wipe down the surfaces and clean them very well before applying the silicone. The release agents and wax they use on baths and tiles can make even the best silicone come unstuck in no time.
#8 | |
Trade: carpenter/ handyman
91% rubbing alcohol works really good as prep & clean up. A little on your fingers makes the silicone go on like glass.
Steve Quote:
#9 | |
Trade: Construction
Thanks Steve i have some of that here somewhere. Might be a little quicker than the way i do it. I use the handy wipes that remove silicone, paint, wax, grease and so on. Only problem is i have to make sure i dry the area well before applying the silicone. Acetone works well i know but you gotta be so carefull with that stuff. |
I like Green things
Denatured alcohol for cleaning silly cone up.
Silicone trick a granite guy
showed me. Lay in a bead, mist it down with alcohol in a spray bottle and tool it with a finger dipped in alcohol. The caulk won't smear, because it can't stick where you sprayed. Makes you look better than you are.
| The Following User Says Thank You to neolitic For This Useful Post: | stp57 (02-03-2010) |
Trade: Plumbing
Phenoseal is what we use on all the big projects. . . that and GE II.
Keith |
| Whats a good caulk gun for concrete epoxy? | Project_Pat | Tools & Equipment | 18 | 01-02-2012 07:42 PM |
| Tub-Tile joint, grout or caulk?? | Aframe | Ceramic & Stone Tile | 11 | 06-27-2011 02:55 PM |
| Primer Cracking over Caulk | go_hercules | Painting & Finish Work | 11 | 01-19-2011 08:39 PM |
| To Caulk or not Caulk. | HandyHails | Ceramic & Stone Tile | 11 | 03-10-2009 07:45 PM |
| Caulk quality | Ralph6 | Windows, Siding and Doors | 5 | 09-04-2008 06:33 PM |
