Modern Type French Drain
Old 08-03-2008, 10:11 PM   #1
builditright's Avatar
Trade: Field Super
Rewards Points: 29
Does anyone know where i can buy "waterguard" perimeter drains. The company "basement systems" uses it as a type of french drain system to existing basements with water problems. Its essentially a metal conduit that is catching any water that may pour through the foundation wall and channelling it to a sump barrel that then pumps it out.
Easy enough to find a sump system and pump but i have searched the net but i can't find this Water-guard conduit they use. Is it proprietary?? Some body must make it?
Thanks
builditright is offline
Old 08-03-2008, 11:54 PM   #2
Retired Contractor
Pete M's Avatar
Trade: Plumber
Rewards Points: 75
Re: Modern Type French Drain
Here's a link http://www.basementsystems.com/basem...waterguard.php
You can also use 3" sched 40 PVC with holes you drill into it. Then you use 2 different size stone. A larger size all around the pipe (like 3A) then pea gravel over the top. If your going to cement over the top, apply foam insulation over the gravel - otherwise the fresh cement top coat will wick up water from under the gravel and it will not dry and cure correctly. Leave a 1/2" gap between the new patch and the existing wall so the water can get to the pipe and gravel below.
Pete M is offline
Old 08-04-2008, 10:54 AM   #3
Trade: Field Super
Rewards Points: 29
Thanks for this. I just talked to Basement systems and it is there patented product so either i have to have them do it or follow your alternate method.
Thanks
exterior french door construction type sehoy Windows, Siding and Doors 6 07-17-2008 02:51 PM
odd find for drain pipe AustinDB Plumbing 9 11-06-2007 09:48 PM
French Drain Cole Landscaping 6 02-21-2007 06:52 AM
French drain question AustinDB Construction 4 11-01-2006 09:46 PM
French Drain denick Excavation & Site Work 6 04-19-2006 06:31 PM
