Mixing Valve Manifold - Plumbing - Contractor Talk
Old 10-10-2018, 02:20 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 230
Hey Plumeros...
Seen this at several production homes lately. What's the point? All hot/cold water mixed at a central location? Is this a code requirement? Best practice? Liability minimizer? Please enlighten me.
bwiab is offline
Old 10-10-2018, 02:25 PM   #2
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 230
Re: Mixing Valve Manifold
hmm.... not sure why it's rotated like that
bwiab is offline
Old 10-10-2018, 02:31 PM   #3
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 230
I looks like all supply lines run off the manifold... almost like a home run to an electrical panel?
bwiab is offline
Old 10-10-2018, 04:35 PM   #4
duburban's Avatar
Trade: building
Rewards Points: 1,380
It looks like only one line is getting mixed there, I wonder where that one goes.
duburban is online now
Old 10-10-2018, 07:38 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,886
That is a waste of pipe.
Scratch that, it is a waste of whatever they are using in place of pipe.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
TNTSERVICES (10-10-2018)
Old 10-10-2018, 07:40 PM   #6
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 230
The one that is actually mixed most likely goes to a free standing tub.
bwiab is offline
Old 10-10-2018, 09:06 PM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 834
Only one of those lines is mixed hot and cold.
The rest is called a manifold system.
The advertised reason for it, is more consistent water pressure and volume throughout the house, ease of installation, and less fittings to possibly fail at some time in the future.
The real reason is for Uponor and Viega to sell expensive "Mani-block" systems, and miles upon miles of plastic tubing that will end up in a landfill in the near future.
It also has the added benefit of being a plug-and-play system, so any mouth breather can pipe a house, without having to resort to the pesky inconvenience of learning to pipe a house properly, sweat fittings, and learn about pressure, volume, co-efficient of friction, developed line length, etc.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
bwiab (10-16-2018), duburban (10-10-2018), Rio (10-11-2018)
Old 10-10-2018, 09:41 PM   #8
AustinDB's Avatar
Rewards Points: 878
so, where does that one mixed line run? is that blue knob on the bottom to adjust the temp and if so, what device would you want to supply a constant hot temp too?
AustinDB is online now
Old 10-10-2018, 09:44 PM   #9
duburban's Avatar
Trade: building
This is the answer. Itís mixed at the manifold because there is no aesthetic location for a mixing valve near the fixture
Old 10-16-2018, 09:49 AM   #10
3 Jacks 2 Nines
bwiab's Avatar
Rewards Points: 230
Thanks for your input guys. Plumber I spoke with said there is another brand that makes a manifold similar to this that actually has a shut off at each connection. That makes a little more sense where a home owner could shut off each fixture individually, but as configured, I don't see any value in it. Even with the shut offs I don't think I would recommend it unless someone asked for it.
bwiab is offline
Moen stop check valve....? PrestigeR&D Plumbing 8 11-27-2012 03:03 PM
Kohler thermostatic mixing valve problem the rock Plumbing 3 08-16-2011 08:16 PM
Thermostatic Mixing Valve on Water Heater MplsGC Plumbing 15 04-29-2011 09:21 AM
Mixing Valve briandurussel Contractor Swap 0 12-13-2009 03:02 PM
Mixing valve replacement okremodeling Plumbing 12 11-02-2008 11:32 PM
