Main Shut Off Valve
Old 12-20-2008, 02:20 PM   #1
woodlover's Avatar
Trade: Builder/Designer
Main Shut Off Valve
I am doing a small bath remodel and the main shut off valve is not turning the water off all the way,I still get a small 1/4" stream coming out of the laundry tub when I open it to relieve the pressure in the lines ( that is the lowest point in the house ).This house is 90 yrs old and all the plumbing is galvanized pipe. I am cutting out all the old piping to the bath and want to put two lever shut off valves that come off the main water supply line that feed the bathroom. Is there any way I can get these two shut off valves in with out making a big mess in the basement?
woodlover is offline
Old 12-20-2008, 02:57 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Main Shut Off Valve
Call the city water dept, tell them what is up and they will send someone out to help shut the water off on there side of the main shut off.
Ron The Plumber is offline
Old 12-20-2008, 07:50 PM   #3
Fentoozler
Celtic's Avatar
I watched a guy swap out a home's main "live"....there was some water spilled, but the basement wasn't finished so it was a non-issue ~ other than the price for a Sunday night call out
Celtic is offline
Old 12-20-2008, 08:27 PM   #4
valleyman's Avatar
Trade: Kitchen and Bath remodeling
I had the same problem at my house. I just went to the curb and shut the water off at the meter.
valleyman is offline
Old 12-20-2008, 08:29 PM   #5
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
If the place you intend to add the valves is higher than the sink (and not on the same pipe) letting the sink run will get rid of most of that water. I change out angle stops in Apartments that don't shut all the way off a lot and usually don't even drip if it's above a faucet I can let run. A good Shop Vac also makes a decent back-up. Time how long it takes to fill a gallon jug and multiply that by the 10 to 20 gallons your Shop Vac holds...That's how long you have to work.
olyteddy is offline
Old 12-20-2008, 08:41 PM   #6
The Grand Wazoo
KillerToiletSpider's Avatar
Freeze it and replace the main shut off.
KillerToiletSpider is offline
Old 12-21-2008, 05:23 PM   #7
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
Agree 1000% freeze and replace is by far the easiest fastest way.
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
Old 12-21-2008, 06:30 PM   #8
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Be a man, do it live. Your not a plumber unless you've got a few live repairs under your belt. JK. Freeze it if you have pipe freezing equipment. You could prolly rent some if you daon't have any or pay someone to do it.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 12-21-2008, 06:35 PM   #9
Professional Instigator
rbsremodeling's Avatar
ok am I missing something here. In dc there is a house main shut off and a street shut off.
If the house shut off is broken we shut the street shut off down. replace the house shut off and bingo your a hero
rbsremodeling is offline
Old 12-21-2008, 07:05 PM   #10
Houston's's Avatar
Trade: Remodeling, Replacement windows,
yeah, some thing here in Baton Rouge LA
Houston's is offline
Old 12-23-2008, 09:11 AM   #11
metx's Avatar
Trade: plumber
use a jet sweat .or snake bite or compression fitting .or rent a propress .live baby live
metx is offline
F#@%ing shut off valves Philly Dude Plumbing 24 11-30-2008 07:48 AM
main trips pat c Electrical 13 08-20-2008 07:05 AM
check valve on the sewer main? builditright Plumbing 10 06-04-2008 02:31 AM
Toilet fill valve slams shut MSjogren Plumbing 14 09-23-2007 11:16 AM
Schrader valve shut off tcfred HVAC 3 06-29-2007 04:23 PM
