Maiking PVC DWV Lines More Quite
Old 02-11-2008, 03:30 PM   #1
personalt's Avatar
Trade: GC/Developer
Added a new bathroom where the lines toilet and shower drains come across the ceililng of a 1st floor bedroom.
Being PVC they are somewhat loud. I plan to insulate the cavities they are in but anything else I do to lessen the noise?
personalt is offline
Old 02-11-2008, 05:46 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Maiking PVC DWV Lines More Quite
Use CI pipe, it is a lot quieter.
KillerToiletSpider is offline
Old 02-11-2008, 05:56 PM   #3
I'm prescient!
I somehow knew just what you would say.
neolitic is offline
Old 02-11-2008, 08:23 PM   #4
Putty Truck's Avatar
Trade: hjrafiuoashfed
I'm prescient!
Bush died and left you president? How'd that work? Can I be Secretary of Girlie Bars?
Putty Truck is offline
Old 02-11-2008, 08:32 PM   #5
mickeyco's Avatar
Trade: Squirrel Handler
No, that position has already been filled.
mickeyco is offline
Old 02-11-2008, 10:29 PM   #6
Al Smith
A W Smith's Avatar
Don't flush upstairs till the guests leave. That way they wont have to play "guess the length of that stool" As it plops down into the elbow above the living room and passes over head then drops into the basement waste line.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 02-11-2008, 10:40 PM   #7
Once again,
I knew just where this thread
was going as soon as it started!
neolitic is offline
Old 02-11-2008, 10:46 PM   #8
Al Smith
A W Smith's Avatar
Once again,
I couldn't resist, This thread was begging for it.
Al Smith
Old 02-12-2008, 04:52 AM   #9
I wanna girlie bar.
There's a crime family that has a few bars in the Seattle area, right? The grandfather got successfully sued for sexual harassment by a dancer.
Old 02-12-2008, 06:23 AM   #10
personalt's Avatar
Trade: GC/Developer
Pipe is already run and just to much to redo in cast iron. Is there anything I can do to make more quiet?
I would imagine giving it more mass would do it. Roof cap cement might help but that would make a giant mess
Old 02-12-2008, 07:40 AM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Try some Ear Plugs
Ron The Plumber is offline
Old 02-12-2008, 07:46 AM   #12
Pro Plumber
Trade: Plumber
Truthfully, they do make sound board, sure it's more expensive the CI.
Old 02-12-2008, 07:51 AM   #13
Pro Plumber
Trade: Plumber
What is ... Sound Deadening Board?
Sound Deadening Board is a specially made structural fiber board product designed for use in wall systems where sound control between rooms is desired.
http://www.housingzone.com/article/CA466516.html?q=stc
Old 02-12-2008, 11:22 AM   #14
Here goes...
You can try rigid fiberglass insulation,
with resilient acoustic channel, and ideally
a double layer of 5/8" drywall.
At least 1 layer of 5/8".
If you really want quiet, you might try
the above fiberglass and resilient channel
(auralex is one brand) with "Quiet Rock".
"SED" is another brand of "sound proofing" drywall.
Pricey is a word that comes to mind with
either drywall brand.
But then, the pretense that we don't have
animal functions is priceless!
neolitic is offline
Old 02-12-2008, 12:11 PM   #15
bob_cntrctr's Avatar
Trade: renovator
Cellulose fibre insulation.
Check out this table:
http://www.soundsmart.ca/sound-absorption.aspx
Note that except for occupied seating, fibreglass batts and cellulose fibres have the highest Noise Reductin co-efficients. BUT - this table shows for 3 1/2" thick fibreglass batt versus just 1" thick cellulose. Taken per inch of material, fibreglass nrc = ~ 0.3 whereas cellulose =~ 0.5 - 0.75.
Fill your box with cellulose fibre. Modern stuff is treated with boric acid and other anti-mould agents so it won't go mouldy if there's ever a drain leak.
bob_cntrctr is offline
Old 02-12-2008, 12:38 PM   #16
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
If only they paid by the pound...
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 02-12-2008, 08:16 PM   #17
troubleseeker's Avatar
Contact an insulation distributor for some sound proofing. There are different types, some sheet goods and some flexible wraps, that are available. It is commonly used in the marine industry to quite machinery room noises.
troubleseeker is offline
Old 02-13-2008, 01:12 AM   #18
Historic specialist
tdavis's Avatar
Trade: General B100 Utah
we have wrapped a lot of ABS in grace ice and water shield and it seems to work pretty well. try a short section and see what you think.
TD
www.EnoceanWireless.com
Wireless lighting control, without using batteries
Use the Discount Code "Contractor" if you'd like...
tdavis is offline
Old 02-13-2008, 02:45 AM   #19
Sportbilly's Avatar
Trade: Licensed Electrician
Automotive Dynamat comes to mind, but not cheap, once again. Works on the principle of adding mass, reducing harmonics.
Legal? I have no idea. Effective? I have no idea, just a thought.
Sportbilly is offline
Cleaning Grout Lines housepainter Flooring 12 02-10-2008 02:38 AM
Lead supply lines? orson Plumbing 3 02-09-2008 11:42 AM
Trouble with roller lines using 18" wooster KJLinden2002 Painting & Finish Work 16 01-01-2008 09:55 AM
Bonding Plastic Water/Gas Lines? jevorik Electrical 3 12-29-2006 12:24 AM
Refrigeration lines and R22 vs. Puron cville HVAC 3 06-25-2006 10:27 PM
