Lye Or Sulfuric Acid, How Do You Pick Which One To Use?
Old 12-12-2007, 12:47 AM   #1
Electric_Light's Avatar
Trade: student again
They're both commonly sold.
Lye solid, lye solution like drano on the strong base side. Concentrated sulfuric acid on the other extreme.
They're intended for same application, but the label does not say which product should be used in which situation.
Input?
Electric_Light is offline
Old 12-12-2007, 06:12 AM   #2
gitnerdun's Avatar
Trade: plumber
Rewards Points: 150
Re: Lye Or Sulfuric Acid, How Do You Pick Which One To Use?
Don't do either call a pro. I've seen Lye harden up like cement and acid will eat up metal pipes and drain snakes. I know, "why do they sell it?". Because people buy it thinking it will work.
gitnerdun is offline
Old 12-12-2007, 10:48 AM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Rewards Points: 2,000
They will sell you anything these days, I agree leave it alone.
Ron The Plumber is offline
Old 12-12-2007, 11:05 AM   #4
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Well it really depends on how badly you want to dispose of the body.
Both of them burn quite well, however, the acid you may find dissolves more tissue.
GregS is offline
Old 12-12-2007, 12:34 PM   #5
Herk's Avatar
Trade: Plumbing
Rewards Points: 150
Lye can form a solid crystal plug and pressure can build beneath it and blow it right into your unprotected eyes.
Sulphuric acid can produce enough heat to melt through plastic pipe, as well as removing the tarry surface from cast iron, causing premature failure.
Enzymatic cleaners may or may not be effective, but they are slow-working.
The best bet is snaking and jetting. Those work as long as the pipe is intact.
There are no dumb questions - just a lot of inquisitive idiots.
Herk is offline
Cleaning a floor to prep for acid stain. Joasis Flooring 7 07-24-2010 01:44 PM
New sunroom addition - Acid stained floor AAPaint Painting & Finish Work Picture Post 12 09-22-2008 01:15 PM
Phosphoric acid davidanbess Painting & Finish Work 4 11-27-2007 07:19 PM
Acid Stain Finish Question North Star Painting & Finish Work 3 02-24-2007 10:10 AM
Acid stain project 6stringmason Masonry 19 02-18-2007 04:40 PM
