Luke Warm Water On Opposite End Of House
Old 01-24-2017, 12:14 PM   #1
hawgcountry's Avatar
Rewards Points: 14
Hello,
I just remodeled a home. The water to the master bath (opposite side of house from water heater) is only lukewarm and not hot. In other bathrooms the water gets hot. I'm trying to figure out what the issue may be....
The home is 2800 SF slab-on-grade. I was thinking that maybe the water is cooling down by the time it gets to the master?? Or is there a chance that it may be mixing with some cold water along the way??
Thoughts?
hawgcountry is offline
Old 01-24-2017, 12:18 PM   #2
Rewards Points: 14
Re: Luke Warm Water On Opposite End Of House
I will add that the house was built in 1970. All the copper pipes coming out of the slab were still in good condition. But obviously I cannot see below the slab.
Old 01-24-2017, 12:30 PM   #3
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
What changed were made to the piping recently?
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 01-24-2017, 12:40 PM   #4
Rewards Points: 14
Added one lavatory in the master bath. Killed the old shower, and turned the tub into a new shower. Killed one lavatory. Also worth noting. The manifold in the master bath was hit with a nail so I had it repaired. The repair was made by a licensed plumber though and it looked to be done correctly.
Old 01-24-2017, 12:40 PM   #5
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 104
Moen cartridge reversed somewhere???
goneelkn is offline
The Following 2 Users Say Thank You to goneelkn For This Useful Post:
Inner10 (01-24-2017), Texas Wax (01-24-2017)
Old 01-24-2017, 12:47 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,923
Shut off the cold supply and see how that affects the hot.
What brand/type mixing valve?
Is there a pressure differential between the hot and cold? Maybe it's back-flowing across the fixture somehow.
MarkJames is online now
Old 01-24-2017, 01:06 PM   #7
Texas Wax's Avatar
Rewards Points: 852
Bawawawa .... only did that once, back in '85 Damn'd new fangled mixing valves.
Texas Wax is offline
Old 01-24-2017, 01:19 PM   #8
goneelkn's Avatar
Rewards Points: 104
Somehow i know that feeling.
goneelkn is offline
Old 01-24-2017, 01:34 PM   #9
Rewards Points: 14
I'm using Kohler valves for shower, and kohler faucets for lavatories. The issue is happening in both the shower and the lavatories.
All valves are brand new so I know it's not a mixing issue at the valves
Old 01-24-2017, 02:04 PM   #10
tgeb's Avatar
Rewards Points: 918
Just because it's new does not mean there could not be an issue with it, or the installation.
I agree with the above suggestion to turn off the cold feed and see how hot the water gets. If it gets nice and hot, you have a backfeed somewhere.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
heavy_d (01-24-2017), ninjaplumber (01-25-2017)
Old 01-24-2017, 02:41 PM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,452
Did you pull the balancing unit and mixer cap before putting a torch to it?
Inner10 is online now
Old 01-24-2017, 03:06 PM   #12
Rewards Points: 14
Understood for the shower, but that would not explain the lavatories. Same problem with all 3 fixtures so I'm quite certain that its not the valves.
I will turn off the cold feeds for the lavatories, however I to not have hot/cold shut off valves at the shower. The valve is the actual shower valve itself
Old 01-24-2017, 03:07 PM   #13
Rewards Points: 14
Yes
Old 01-25-2017, 09:37 PM   #14
ninjaplumber's Avatar
Trade: Plumbing
Rewards Points: 26
Recirc line.
ninjaplumber is offline
Old 08-16-2017, 04:33 AM   #15
HotDawg's Avatar
Trade: Plumber
Rewards Points: 30
Resolved?
Mr D
Work as a Manchester Plumber
HotDawg is offline
Old 08-16-2017, 04:38 AM   #16
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,840
The OP signed up here 01/24 - has NOT been logged on since 01/24.
Likely a DIY posing as a GC.
SmallTownGuy is offline
Old 08-19-2017, 10:47 AM   #17
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 168
My thoughts as well.
Ernie in Dawson is offline
Under sink water filters ? My house We Fix Houses Plumbing 8 11-22-2016 04:24 AM
trouble shooting water heater Tom M Plumbing 9 02-14-2016 09:12 AM
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 07:02 PM
Unofficial CT Handsaw Challenge Warm Up Meet. chewy Off Topic (Non Trade) 9 09-12-2012 11:18 AM
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
