Loud Pipes From Well - Page 2 - Plumbing - Contractor Talk
Old 06-08-2018, 11:36 AM   #21
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 834
Re: Loud Pipes From Well
Hard to say without seeing it, but here's some possibilities:
If the pressure tank is saturated, then the well pump kicks on every time the water is used, and the pressure tank is no longer acting as a water hammer arrestor.
I'm guessing it has galvanized riser pipe, then switches to copper. If there are no torque arrestors, or they have disintegrated, then the riser could be banging against the well casing every time the pump starts.
The well pump could just be worn out.
Golden view (06-08-2018)
Old 06-09-2018, 06:52 PM   #22
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,799
Originally Posted by Morning Wood View Post
60’ isn’t very deep. Most Wells I know of are over 100’. The lack of depth must have something to do with the pump noise.
My well's only 34', and I've never heard so much as a whisper from the submersible I put in 7 years ago. Hard pipe inside the casing, poly into the house. I often do odd bits of work right within 4-5' of the casing outside, and have never heard any sounds from it.
Tinstaafl is offline
Golden view (06-10-2018)
Old 06-10-2018, 10:13 AM   #23
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,920
Yeah something is definitely unusual. I'm back home, didn't resolve anything and they don't care much (and don't care to pay since they have water), but it would be nice if I could give them some pointers.
Golden view is offline
Frozen Pipes Chenyi General Discussion 15 02-05-2018 10:12 AM
FRP around pipes platinumLLC Construction 5 04-29-2015 09:07 AM
Frozen Pipes... DaVinciRemodel Plumbing 26 02-08-2014 09:43 AM
Pipes to Attic? Old House Mystery. JRSeifert General Discussion 20 10-15-2011 05:15 PM
Loud squealing noise from pipes ChuckEA Plumbing 3 08-19-2006 04:20 PM
