Location Of Shut Off Valve In Condo
Old 09-21-2017, 12:13 PM   #1
eperc002's Avatar
Rewards Points: 28
Hi,
I'm disconnecting all the kitchen appliances, and when I went to turn off the shut off valve under the sink I found out that its pretty stuck.
I know sometimes when we do work in condo they are require to turn off all the water supply for all the apartment in that stack.
I think some condo usually have a main water shut off valve by the water heater, but im not sure... see attach picture. Please let me know how I can know if thats one of the main water shut off or how I can get the main water valve under the kitchen sink unstuck.
Thanks
eperc002 is offline
Old 09-21-2017, 12:23 PM   #2
eperc002's Avatar
Rewards Points: 28
Re: Location Of Shut Off Valve In Condo
Better picture
eperc002 is offline
Old 09-21-2017, 01:03 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,118
Hire a plumber and have the mods put this thread in the wall of shame.
I know this is not your work but damn, that is some of the crappiest work I have seen in such a small place.
Andy.
ScipioAfricanus is offline
The Following 2 Users Say Thank You to ScipioAfricanus For This Useful Post:
GAN57 (09-28-2017), SmallTownGuy (09-28-2017)
Old 09-21-2017, 02:53 PM   #4
avenge's Avatar
Rewards Points: 2,794
Besides the fact you say you're a GC and should have access to a plumber, doesn't the condo have a maintenance crew that may know? Why would the valve at the water heater shut off all water? Did you actually try using pliers to shut off the valve?
Have you ever shut off water before? Gee I think if I shutoff a valve and the water stills runs that would be my first clue that's not the shutoff.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
GAN57 (09-28-2017)
Old 09-21-2017, 04:19 PM   #5
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I like the easy access to the electric panel? OPPS the hot water tank is in the way! I would look for a main valve/meter in the unit before I typed this question, lots less time!
Dave in Pa is offline
Old 09-28-2017, 07:17 AM   #6
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
My guess is the valve in the wall.
Looks like a slum lord's wet dream, pun intended.
RangoWA is offline
Old 09-28-2017, 03:14 PM   #7
GAN57's Avatar
Trade: Licensed Plumber & Inspector
Rewards Points: 76
Also a nasty safety violation. The Temp & Press. relief is reduced. Let alone direct connection with copper.
Call a licensed plumber.
GAN57 is offline
Moen tub/shower valve no worky right. whatsacubbard? Plumbing 14 03-02-2013 06:37 AM
w.c flush valve mohdmaruf Plumbing 1 02-23-2013 08:19 AM
Hissing from shower valve pbechard Plumbing 2 02-17-2013 02:19 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 09:10 AM
bryant gas valve heavyduty73 HVAC 1 12-16-2009 06:20 PM
