Location- Material Prices
Old 01-16-2008, 09:35 PM   #1
masterk's Avatar
Trade: Plumbing
Lets see what material cost are through out the country.
I'm In Baltimore Maryland.
50 gal. gas A.O. Smith water heater $ 370.00
3/4 L copper $ 2.80 per foot
1/2 L copper $ 2.25 per foot
100 roll of 3/4 K copper $ 345.00
3/4 ball valve $ 7.50 1/2 $ 6.00
masterk is offline
Old 01-16-2008, 09:45 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Location- Material Prices
We rarely buy water heaters.
3/4 L we are getting for 2.55 a foot with a thousand foot ordered, 2.05 a foot for 1/2. I usually buy two thousand feet at a time of 1/2, 3/4, and 1" mixed.
We rarely buy K copper, I can't remember the last time we did.
I can buy ball valves in bulk, imported 4.75 for 3/4 and 3.50 for 1/2, we use these as throw away valves only. We buy domestic made valves for the valves we intend to use, usually Milwaukee, 13.00 for 3/4 and 10.50 for 1/2.
KillerToiletSpider is offline
Old 01-16-2008, 09:55 PM   #3
smellslike$tome's Avatar
Trade: plumbing
???throw away valves???
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
Old 01-16-2008, 09:59 PM   #4
The Grand Wazoo
When we do riser shut downs in high rises, we install valves that will not be accessible when the unit is framed and drywalled, so when the framing is up we install isolation valves, turn on the throw away valves, and remove the handles, thus "throwing the valve away".
Old 01-16-2008, 10:10 PM   #5
Trade: plumbing
Gotcha. So they are not actually thrown away as in a temporarily installed valve and the quality of the valve is less of an issue since ultimately it will remain perpetually open.
Of course I've never seen you Killer but I'm thinking you must be skinny as a post since you spend your life dragging tools, materials, etc. up and down and around high rises. My limited experience in commercial work tells me it's about a thousand steps every time you have to go get something.
Old 01-16-2008, 10:14 PM   #6
The Grand Wazoo
I wear twenty nine inch waist pants.
There is a reason all my estimates are based on $1900.00 per fixture, and yes, an ice maker on the fridge is a fixture.
Old 01-16-2008, 10:23 PM   #7
Trade: plumbing
Knew it! Had to be.
Material choice for fascia. kclapper Windows, Siding and Doors 5 07-31-2007 11:14 PM
drywall material prices - material only D-ball Drywall 1 12-27-2006 08:37 AM
Setting prices J&J Home Imp. Flooring 13 12-04-2006 12:48 PM
SW Raising Prices Again BMAN Painting & Finish Work 22 10-24-2006 02:22 PM
Material Prices Cooterbuilt Construction 3 09-07-2005 11:38 PM
