Locating Copper Behind Drywall
Old 03-12-2010, 08:34 PM   #1
davitk's Avatar
Trade: Perfessional Contracter
surgically.
Some dumb*** finished a basement with drywall ceilings and didn't leave access for the 40 year old hose bibb shut-offs.
Any (good) ideas?
davitk is offline
Old 03-12-2010, 08:45 PM   #2
mikeswoods's Avatar
Trade: interior remodeling
Re: Locating Copper Behind Drywall
Figure out where the pipe enters the basement and open the ceiling--Shut off the water to the house and install a new shut off---if the old shut off is in the on position and not leaking you're done.
The didn't bury the shut off while it was turned off,did they? That would be a royal pain.
(you aren't the guy that did this?)HaHa--Mike--
mikeswoods is offline
Old 03-12-2010, 09:04 PM   #3
davitk's Avatar
The ceiling was put in two years ago (not me) and conditions have not been right for a freeze up - yet.
How do I locate the shut-offs? Those X-ray glasses I ordered from an ad in Popular Mechanics turned out to be fake.
davitk is offline
Old 03-12-2010, 09:09 PM   #4
BCConstruction's Avatar
Trade: Construction
can you not hear them running if you open them up. We used to do this quite often when tracking down water pipes. you can get pretty much within a few inches if you can hear it.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 03-12-2010, 09:31 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Originally Posted by davitk View Post
surgically.
Any (good) ideas?
Run water through that hose bibb and no where else, and use a mechanics stethoscope to hear where the water is running, once you pinpoint it cut an exploratory hole 18" from the outside wall, there is a good chance you will find your valve close to that, if not you have a hole to look into it further.
KillerToiletSpider is offline
Old 03-12-2010, 10:25 PM   #6
DetailHandyman's Avatar
Trade: Professional Handyman
On occasion, I've had luck locating buried pipes by running screws through them.
The cat box ain't gonna clean itself.
DetailHandyman is offline
The Following User Says Thank You to DetailHandyman For This Useful Post:
davitk (03-13-2010)
Old 03-13-2010, 09:21 AM   #7
davitk's Avatar
Thanks guys, you put me on the right track. I will stop by Harbor Freight today and pick up a mechanic's stethoscope and some 12" drywall screws.
Wish me luck!
davitk is offline
Old 03-13-2010, 10:39 AM   #8
Wood Craftsman
PrestigeR&D's Avatar
Talking
I have a Deep Metal Stud scanner I use- that works, or you can go primitave on it with the Y wood stick,just kidding,
Brian
PrestigeR&D is offline
EcoRock Drywall Sir Mixalot Drywall 2 06-04-2009 05:39 PM
Have any of you been following this Frankawitz Drywall 5 04-12-2009 09:47 PM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 06:19 AM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 11:16 AM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 11:52 AM
