#21 |
Trade: Construction
Re: Liar..or Moron?
Mike is also correct that you can add a Inhibited Antifreeze. Make sure that it's not a normal anti freeze as some of these are not compatible with the new aluminum heat exchagers. They should protect you to about -5 to -6 or you can do a massive dose which will cover you to about -20.
| The Following User Says Thank You to BCConstruction For This Useful Post: | mikeswoods (08-30-2009) |
#22 |
Trade: interior remodeling
Re: Liar..or Moron?
We like our friends despite their flaws.
Some times all you can do is speak your peace and then shut up. He's an adult. |
| The Following User Says Thank You to mikeswoods For This Useful Post: | mics_54 (08-30-2009) |
#23 |
Trade: contractor
Re: Liar..or Moron?
propylene glycol will work of course but the manufacturers do not recommend its use. I do use it in traps and appliances for winterizing though.
#24 |
Trade: contractor
Re: Liar..or Moron?
Well..I guess I can wait till some tragedy occurrs and then I get to say "I TOLD YOU SO"
#25 |
Re: Liar..or Moron? He's a smart fellow,Your friend should be able to winterize his place.If he chooses not to
#26 |
LRG WoodCrafting
Re: Liar..or Moron?
I am not sure if I understand the issue. Turn off the power to the pump, drain the entire heating system down dry, turn off the power to the oil burner. No water in the system, so it cant freeze, no power to the boiler so it can't dire up.
#27 |
Trade: hvac/electric
Re: Liar..or Moron?
I heard turning off the heat for long periods of time in the winter in cold climates can damage a foundation.
#28 |
Chief outhouse engineer
Trade: mason
Re: Liar..or Moron?
or,
you could be a helpful friend and just check in on the house once a week.
D K & Sons The maintenance schedule for brick 1. Stand back and say "man that looks nice!" 2. Repeat as often as needed. |
#29 | |
Trade: Construction
Re: Liar..or Moron?Quote:
This is just one of the issues when it come to leaving heat off the whole winter. I have seen foundations crack in half due to heat being applied to a cold floor that was left over winter. The home owner had underfloor heating and he returned for his winter vacation home and turned his heat upto max and the floor cracked all the way from the screed to the foundation. He was meant to turn it up very slowly to let the floor expand slowly but he didn't. It can also ruin floors and walls. The other problem is water left in the pipes. You may think that you cleared out the whole system but water over time will build in certain areas like drops and elbows and water will freeze and crack pipes. Your best letting the system run of the frost stat so that it keeps it above freezing and shut of the mains supply. |
#30 |
Trade: contractor
Re: Liar..or Moron?
Well it's an option but I don't recommend it. Not to mention it's a fully furnished residence with all the electronics and niknaks one would expect in a residence. Allowing it to get 20 below inside probably isn't desirable.
#31 |
Trade: contractor
Re: Liar..or Moron?
or,
you could be a helpful friend and just check in on the house once a week. ![]() well I offered but he's too cheap to plow the drive way all winter. (1/4 mile long driveway) |
#32 |
Trade: CHarles Mitchell Cabinets
Re: Liar..or Moron?
Why is he asking what to do, since he has already made up his mind?
Let all hell break lose and then he can hire one of us to fix it. We need the work. Think God we have experts. Charlie Last edited by Charles Mitchel; 09-02-2009 at 11:41 PM. |
| The Following User Says Thank You to Charles Mitchel For This Useful Post: | MACPLUMB (09-03-2009) |
| Moron Builders | leakygoose | Finish Carpentry | 21 | 12-08-2008 12:08 PM |
| You think he's a Moron??? | Mandrake | Health & Safety | 16 | 01-17-2008 07:34 PM |
| The REAL MORON! | neolitic | Off Topic (Non Trade) | 1 | 01-16-2008 09:19 PM |
| Look at this moron! | Magnettica | Health & Safety | 71 | 01-13-2008 06:09 PM |
| friggin moron carpenter | Grumpy | General Discussion | 8 | 09-09-2004 12:49 PM |
