Liar..or Moron?
Old 08-30-2009, 04:36 PM   #1
mics_54's Avatar
Trade: contractor
Liar..or Moron?
Friend of mine moved "outside" to washington last year. He was up this year to sell some stuff and close the house up for the winter (his daughter moved out of the homestead house) His plumber said it wasnt possible to drain the pipes in his house and turn off the well pump because his boiler was heating the water for the hydronic baseboards. I told my friend his plumber is full of crap and just didn't want to mess with the job. He originally installed the bolier and plumbing and didn't install the necessary isolation valves and arrange the plumbing for the purpose of winterizing the house.
My friend bought an alarm system to monitor the temp and power but I told him those fail sometimes and the risk of leaving his house empty and depending on his heat system with a well pump ready to pump thousands of gallons into his house was too great.
His plumber actually tried to tell him the well can't be turned off because the boiler needs water. So...is the plumber a liar...or a moron?
mics_54 is offline
Old 08-30-2009, 04:48 PM   #2
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
...and what's really wierd..is that my friend seems unconvinced that I am giving him solid advice and that his plumber is wrong. He actually got angry at me for telling him that he's making a mistake.
mics_54 is offline
Old 08-30-2009, 05:22 PM   #3
Professional Instigator
rbsremodeling's Avatar
Re: Liar..or Moron?
If this is true then he can't winterize the house as you described so why is he a liar?
rbsremodeling is offline
Old 08-30-2009, 05:24 PM   #4
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
Think, then ask an intelligent question.
mics_54 is offline
Old 08-30-2009, 05:28 PM   #5
Re: Liar..or Moron?
Seems intelligent to me. I quoted what you typed.
Maybe the plumber is not the moron here? is that better?
Old 08-30-2009, 05:33 PM   #6
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
Well I could certainly install the two valves necessary to winterize the system..you probably couldn't. The point to any sentient individual is that the plumber says that it can't be done, which is total BS. Now if you have anything of value to contribute to the thread please do.
mics_54 is offline
Old 08-30-2009, 06:12 PM   #7
Thom
thom's Avatar
Re: Liar..or Moron?
the cost to close the house up for the winter may be more than the cost of providing minimal heat.
Flushing the traps and filling with antifreeze, draining then blow drying all the water piping, and something might get missed anyway.
If it was my house, I'd keep it heated.
thom is offline
Old 08-30-2009, 06:45 PM   #8
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
OK I see I'm not connecting here.. If the water pump is left energised, if he has a heat failure and pipes break the pump could pump water in his house untill some one turns it off. If the pump is turned off and potable water side is drained, the only damage would be a few gallons of water on the floor somewhere instead of thousands of gallons. I didnt say turn the heat off. I said turn the well pump off. The plumber told him it couldnt be done because the boiler requires water from the well for makeup water in the boiler system. The single pressure tank charge would supply sufficient water for make up for the boiler to operate for a year unless he had a bad hydronic leak. The well pump should be turned off, the potoble water side drained and the boiler left operational on winter mode. Surely I can't be the only one seeing this.
mics_54 is offline
Old 08-30-2009, 06:50 PM   #9
Illinois Licensed Plumber
SewerRatz's Avatar
Trade: Illinois Licensed Plumber
Re: Liar..or Moron?
If the boiler fires dry it will ruin the boiler. It always needs make up water. If you are really worried about a burst pipe put in a WAGS system or the Watts leak detector system where if they detect a leak it will shut off the water supply.
SewerRatz is offline
The Following 2 Users Say Thank You to SewerRatz For This Useful Post:
MACPLUMB (08-31-2009), mics_54 (08-30-2009)
Old 08-30-2009, 06:56 PM   #10
BCConstruction's Avatar
Trade: Construction
Re: Liar..or Moron?
It depends on if he has a pressurized heating system or a open vented system. If he has a open vented system then yes water will have to be left on but if he has a pressurized system then the water can be turned off. Even open vented system dont require a lot of water and the header storage tank would normally hold enough water to keep the system running for months but water does evaporate in these system so the water being left on is really a must.
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 08-30-2009, 06:57 PM   #11
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
Now thats a reasoned alternative. However the boiler does need make up but the pressure tank will supply make up for months if the pressure doesnt bleed off from leaks. The well pump doesnt need to stay energised for the boiler makeup to function off of the charge in the pressure tank. Boiler make up rarely requires a cup full of water, does it?
mics_54 is offline
Old 08-30-2009, 07:00 PM   #12
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
This boiler is fairly modern...I doubt it will ignite with low water in the system.
mics_54 is offline
Old 08-30-2009, 07:02 PM   #13
Trade: Construction
Re: Liar..or Moron?
If the system has been plumbed in correctly then a pressurized system should have zero water leak but even if it does you need to open a charging valve to charge the system back upto at least 0.6bar to get the pump to kick back in and the system run. even if you left the well water on, the system would not charge it's self back to the recommended pressure.
Old 08-30-2009, 07:05 PM   #14
mics_54's Avatar
Trade: contractor
Post
Re: Liar..or Moron?
The system is equipped with an expansion tank and automatic make up.
mics_54 is offline
Old 08-30-2009, 07:05 PM   #15
Trade: Construction
Re: Liar..or Moron?
If the system has a pressure dial built inot it then it's a pressurized system and 99% of these systems will not run if pressure drops below 0.6bar. If they system loses that kind of pressure to drop below 0.6bar then the system need to have a pressure test done and the leak found.
Old 08-30-2009, 07:09 PM   #16
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
As I'm thinking about this I am beginning to wonder if the moron isnt my friend that owns the house. That would explain why he got irritated at me for telling him it was stupid to leave his house unattended and not winterized..
OK the plumber is off the HOOK!
mics_54 is offline
Old 08-30-2009, 07:11 PM   #17
Trade: Construction
Re: Liar..or Moron?
I have never heard of a automatic make up but if it has expansion tank then it's a presurized system. The system when upto pressure should be disconnected from the main supply so that if the check valve decides not to work then the heating water wont get pushed back into the mains water line and contaminate the mains drinking water or if someone turns on the refil valve it wont keep filing up the system to what ever mains pressure you have and cause an explosion.
As an example you should have a isolation valve then a removable flexable hose then a check valve(Non return valve) so that when system is charged you can shut of the water supply and cap the valves after you remove the flexi.
But you can shut of the mains water with this type of system. Also most new boiler have a low limit stat so that when the temp drops below a certain tempreture the system will fire up and run no mater if the stat is turned off or not. This is so pipes dont freeze over winter.
Old 08-30-2009, 07:19 PM   #18
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Liar..or Moron?
Based on the tone of this response, any thoughts on the subject I may have I will keep to myself.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
Old 08-30-2009, 07:30 PM   #19
mikeswoods's Avatar
Trade: interior remodeling
Re: Liar..or Moron?
First off I am not a hydronic heating guy.How ever I have installed four of them my self and use hot water baseboard heat in my own house.
Not only can the system be isolated--They can be filled with antifreeze.
Isolated antifreeze systems are used here for garage heating,(insurance against loosing the floor coils if a system failure occurs.)
I use PORTER PIPE AND SUPPLY, Addison Il. for boilers and engineering of the systems. You probably have a company near you with an engineer that can answer your questions using knowledge instead of bull sh#t.
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
Old 08-30-2009, 07:33 PM   #20
mics_54's Avatar
Trade: contractor
Re: Liar..or Moron?
I'd almost bet he didn't even consult his plumber on winterization. I know of the plumber that installed his system. I can't imagine him telling my friend that it can't be done.
mics_54 is offline
Moron Builders leakygoose Finish Carpentry 21 12-08-2008 12:08 PM
You think he's a Moron??? Mandrake Health & Safety 16 01-17-2008 07:34 PM
The REAL MORON! neolitic Off Topic (Non Trade) 1 01-16-2008 09:19 PM
Look at this moron! Magnettica Health & Safety 71 01-13-2008 06:09 PM
friggin moron carpenter Grumpy General Discussion 8 09-09-2004 12:49 PM
