Leaky Waterfall Faucet In Hot Tub
Old 09-25-2007, 11:05 PM   #1
Dream Maker
Mr. D's Avatar
Trade: residential construction
recently had a hot tub installed for client. after running water and shutting of hot and cold valves. faucet drips. if i run my fingers along the lip of waterfall it drips even more. i did that for five minutes and got good amount of water to keep coming out. it never did seem to stop.
I called my plumber and he said valves seem to be good. are there some type of adjustments to make for waterfall spouts? or is it probably just a bad spout? This spout is built into the tub also.
Mr. D is offline
Old 09-26-2007, 09:32 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Leaky Waterfall Faucet In Hot Tub
Even if a stem may seem good does not mean it is. Replace the stems.
Ron The Plumber is offline
Old 09-26-2007, 05:24 PM   #3
Grumpyplumber's Avatar
Trade: Plumber
Whats the name on it?
Grumpyplumber is offline
Old 09-26-2007, 06:12 PM   #4
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
[quote]my Guess Would Be---moen./quote]
PARA1 is offline
Old 09-26-2007, 06:47 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
If it is a Jacuzzi brand integral waterfall filler, they use a variety of cheap stems, mostly Nibco. If it is a Kohler, it probably has a nick in the ceramic on the bottom of the cartridge, in either case you need to replace the cartridge.
KillerToiletSpider is offline
Old 09-26-2007, 07:38 PM   #6
Dream Maker
Mr. D's Avatar
the tub is acryline, the valves are kohler. thanks for the ideas fellas
Mr. D is offline
Kitchen faucet issue dansdad Plumbing 5 07-18-2007 12:53 PM
leaky pipe GWHRsuperhero Plumbing 1 04-24-2007 09:16 PM
taking on my first waterfall job need help pinnacle1 Landscaping 12 12-10-2006 12:41 PM
Moen faucet question Robie Plumbing 2 04-02-2006 04:52 PM
price to replace faucet? wallyofthenorth Plumbing 2 12-09-2005 11:24 PM
