Leaking Hard To Reach Fitting HELP NEEDED
Old 01-13-2004, 06:43 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
My shower was leaking into a wall after being used. I had narrowed down the leak to the shower arm. I thought it would be at the joint where the chrome arm connects to the 1/2" female fitting inside the wall. Upon cutting around the drywall where the stubout comes out of, I see the leak is at the soldered joint between that 1/2", elbow fitting and the copper pipe inside the wall.
It is very tight, I do have access to the wall behind. But with the backer board the fitting is screwed too... I dont trust my soldering skills.
What is the way to go about fixing this?? Is soldering the only fix? If you had to access that 1/2" 90' elbow from behind the wall, about how big of area should I cut... stud to stud? Also what do I do about that 2x4 that the elbow is attached to?
Any help is greatly apreciated.
Old 01-19-2004, 06:29 AM   #2
Bjd's Avatar
Re: Leaking Hard To Reach Fitting HELP NEEDED
Take it from a pro;
Walls can be fixed in a few hours time, fires destroy whole houses.
Do yourself a big favor and cut a huge hole in the wall, make the best repair and fix the hole and forget about it.
Weather the hole is small or large the time for the repair runs about the same so why not go the safe way.
Bernie
Bjd is offline
Old 02-15-2004, 08:19 AM   #3
stardevelopment's Avatar
Have you fixed the problem?
stardevelopment is offline
Old 02-15-2004, 01:39 PM   #4
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
please call a plumber or friend who has the neccery skills, i can,t teach you to sweat pipe over net, too much to lose not enough to gain .
take a deep breath good luck
Driftwood is offline
Trailer: Customizing ideas needed. Long Robie Vehicles 195 11-06-2011 11:32 AM
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
Ideas For Cutting Hard Costs. wackman General Discussion 18 11-22-2006 02:53 PM
leaking basement HUDSONVALLEYEXT Construction 4 10-12-2006 10:30 PM
Hard Times or Hard Up?? Debookkeeper Off Topic (Non Trade) 13 08-29-2006 07:42 PM
