Leak Detection
Old 02-04-2008, 07:05 PM   #1
Future Mod...
rex's Avatar
Trade: Master Plumber
Leak Detection
got called to a chinese restaurant today for a leak....got there and the floor was soaking wet and warm....so i started by shutting off the hot water had the china men soak up all water and then i turned water back on and it showed up again...
so i started tracing the line back found a few looped 1/2 " lines under dishwasher and service tubs... cut and capped the hot line turned the water back on and i can still here water running in pipe and water is still bubbling from stress crack in slab...
my plan is after i located feed line is to cut cap and fish pex across dropped celing in kitchen down wall and tie back in to the line....
well i cant find the line and im not about to start beating holes in the wall tiled wainscotting on one side and fancy wall paper on the other...
i have it down to a certin section and i guess my question with out calling in american leak detection 395 2 hour minimum is there any way of rigging up some kind of continuity tester to find the line.....
rex is offline
Old 02-04-2008, 08:04 PM   #2
K2's Avatar
Re: Leak Detection
I found an under slab leak one time by filling the line with air and listening with a stethoscope. Came within 3 inches of where a concrete grade stick, (wood), went through the copper. Just a thought.
K2 is offline
Old 02-04-2008, 10:15 PM   #3
Putty Truck's Avatar
Trade: hjrafiuoashfed
Re: Leak Detection
Repipe the whole hot water system. There may be more than one leak anyway.
Putty Truck is offline
Old 02-04-2008, 10:26 PM   #4
Patrick's Avatar
Re: Leak Detection
How were you not ill after being in that kitchen so long
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 02-04-2008, 10:30 PM   #5
cleveman's Avatar
Trade: custom home building
Re: Leak Detection
install floor drain with garbage disposal in it. Have restaurant workers squeegee floor each night into floor drain. Will be good for sanitation.
cleveman is online now
Old 02-04-2008, 10:38 PM   #6
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
Re: Leak Detection
WILL BE GOOD FOR WON TON SUEY SOUP TOMORROW
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 02-05-2008, 12:32 PM   #7
Moderator
Double-A's Avatar
Re: Leak Detection
I'd let the restaurant owner decide on the location fee.
Price him a hot water re-pipe on the kitchen/affected areas and let him know, that even if you bust his floor for a repair, there may be more damage and a re-pipe is recommended unless you can point to an outside failure source, like a penetration.
If its eaten up from aggressive fill material, improper sleeving, or electrolysis, then he's looking at a complete re-pipe of the restaurant anyway.
In other words, locating the problem might be wasted monies, like Putty said.
New York Times, July 20, 2006
Double-A is offline
Fixing PVC Joint Leak personalt Plumbing 6 02-03-2008 07:48 PM
water main leak detection dayexco Excavation & Site Work 16 01-10-2008 11:38 AM
Gas Line - Can't Find The Leak jman116 Plumbing 27 08-19-2007 11:19 AM
Leak on Chimney Fishheads Roofing 6 07-21-2007 07:07 AM
Leak in Ruud air handler in attic Geeteex HVAC 1 03-17-2006 08:07 PM
