Lead Question
Old 03-16-2010, 04:42 PM   #1
ch0mpie's Avatar
Trade: Geotechnical PE
Lead Question
A previous owner of my house built some stupid enclosure for the water meter. The water company wants to put in a new meter now and told me I have remove the enclosure. Upon doing so I found that the pipe coming from the street to the meter is lead. Should I be conserned? I read the CDC's website, it explains all about running your water for 2 min. befored drinking or cooking. Wondering if you guys think I should consider replacing this pipe?
ch0mpie is offline
Old 03-16-2010, 05:02 PM   #2
Framer53's Avatar
Trade: Framing
Re: Lead Question
You could test the water first to see if it really is a problem now or can be put off.
Personally, if you can afford it, replace it.
Framer53 is offline
Old 03-16-2010, 05:02 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Lead Question
There are thousands upon thousands of lead water services in Chicago, and no one has proven that they have killed or sickened a single person.
KillerToiletSpider is online now
Old 03-16-2010, 05:44 PM   #4
Framer53's Avatar
Trade: Framing
Re: Lead Question
Has become an issue around here. Supposedly it elevates lead level in children.
Framer53 is offline
Old 03-16-2010, 06:17 PM   #5
The Grand Wazoo
Re: Lead Question
Show me proof that it is directly related to the water services. Lead water services almost always have a mineral lining on the inside of the pipe from the lime and iron in the water clinging to the inside of the pipe walls, the water itself is not in contact with the lead.
Old 03-16-2010, 08:54 PM   #6
BCConstruction's Avatar
Trade: Construction
Re: Lead Question
Just like the EPA RRP rule lead can be blown way out of propotion. I have seen hundreds of lead water mains and never ever ever heard of a single problem from them but they are ment to be a higher risk of lead exposure for home owners. Way above lead paint infact. Test the water then if you find even small traces of lead and can afford it then change it or get a good water filter. Our lake house has very high lead levels and iron levels and our water filter can remove it without problems. Wernt cheap though.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
What Internet lead services should do to corner the market Mike Finley Business 45 03-26-2010 09:17 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
New Lead from contract wars Any Season General Discussion 0 04-26-2008 06:03 PM
