Lead And Oakum Closet Flange
I'm doing a bathroom renovation where I had to replace the subfloor. There is a 4" cast iron ideal bend, with the flange attached with lead and oakum. I replaced the subfloor with a solid piece of plywood. So now I need to seperate the flange from the ideal bend, push it thru the hole I'll cut in the plywood and re-attach it to the ideal bend. Is there any easier way to do this ? I'd prefer to not have to re-attach with lead and oakum. Could I bolt the existing flange to the bottom of the subfloor and then attach a flange extender on the topside ?
#2 | |
Trade: carpenrty, remodeling , residential
Re: Lead And Oakum Closet FlangeQuote:
http://www.fernco.com/plumbing/donut...e-pipe-gaskets Last edited by odellconstruct; 01-06-2009 at 08:27 PM. |
any plumbing supply has em , and prob cheapo and blowes too
just remove to nearest hub and run pvc makes it easier hope it helps |
#4 | |
The Grand Wazoo
I like Green things
Yeah, and that is always a fun job. It always makes me nervous doing that, but it is usually the only way.
odell, If I use that gasket you suggest, I still need to support the weight of the ideal bend and the 3' run back to the stack. How should I do that ?
Re: Lead And Oakum Closet Flange |
The Grand Wazoo
Then I don't know what to tell you, when I do something I do it right.
Plumbing is a Profession
Trade: Plumbing & HVAC
What't to be afraid of ? You get you some lead, no wheel weights though gotta be the pure stuff. Then gather up the trusty old lead pot and ladel along with some white oakum and your pouch of lead tools. Make sure to dress up the ends if they havn't been used in a while. Then pack in the oakum, pour and set the lead and you're all done. Piece o Cake.
#10 | |
Capra aegagrus
Trade: Plumbing
If this is in a commercial building it must be piped with cast iron. If it is residential the cast can be cut and use a mission band to connect cast iron to plastic.
Yeah I'm definitely gonna just cut out the cast iron and replace with pvc. In fact I don't even have to cut anything as there is a rubber connection 2 feet away from the ideal bend. Sometimes I get carried away with how "perfect" I can make a job.
Pro Plumber
Trade: Plumber
You could just use a insta set closet flange. After you remove the old one. Code approved.
