Kohler Bathtub Installation - Plumbing - Contractor Talk
Old 01-22-2018, 01:49 PM   #1
local2035's Avatar
Trade: Drywall
Hello everyone Have an interesting question about Kohler bathtub installation
Im planning to mount a Kohler faucet (K-T398-4) on the deck of a tub (Kohler K-6369). I have inch copper from the floor, and inch copper from the faucet (K-300-KR).
Since the area between the tub and tub-skirt is narrow and curved, I am planning to install x COP Male adapter on both ends and use a flexible washing machine supply line to connect the two ends.
Any issues/concerns? Any alternative option? Thanks
local2035 is offline
Old 01-22-2018, 03:29 PM   #2
avenge's Avatar
Rewards Points: 2,948
Re: Kohler Bathtub Installation
Why? Just use pex or copper.
avenge is offline
Old 01-22-2018, 04:25 PM   #3
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
You using whaaa? waschin macheen hose??? Hoochiemomma !!
kirkdc is offline
Old 01-22-2018, 05:12 PM   #4
Tom M's Avatar
Rewards Points: 7,100
Union rocker doing unpermitted, unlicensed plumbing.
Tom M is online now
greg24k (01-22-2018)
Old 01-22-2018, 06:21 PM   #5
rrk's Avatar
Rewards Points: 2,306
Why does that surprise you ? especially where we live. Along with police and paid fireman, Union workers are known to do things that way.
rrk is online now
Old 01-22-2018, 07:14 PM   #6
tjbnwi's Avatar
Rewards Points: 3,970
On the Kohler tub listed the flexible connectors are required to assemble the tub when using a deck mount faucet. It's in the instructions. I've never done it with flex connectors, the ones I've done had floor mount tub fillers.
I dont see why the braided washing machine hoses wouldn't work.
tjbnwi is online now
Old 01-22-2018, 07:56 PM   #7
Tom M's Avatar
What are you saying they undermine our living while double dipping making two? Not around here.........
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
greg24k (01-22-2018), rrk (01-22-2018)
Old 01-22-2018, 09:42 PM   #8
kirkdc's Avatar
I've used shark-bytes and pex to plumb a few but if there's no access to it it's gonna get copper-sweat.
kirkdc is offline
Old 01-22-2018, 10:14 PM   #9
avenge's Avatar
I've done them with copper, pex, flex water supply lines and flex copper lines that were part of the faucet. Don't recall ever having one that required flex lines.
Sure washing machine hoses would work but wouldn't be on my list of options.
avenge is offline
Old 01-23-2018, 07:56 AM   #10
local2035's Avatar
Trade: Drywall
Tjbnwi is correct, the Kohler tub listed flexible connectors as a requirement. Called Kohler and confirmed.
I thought about flex copper line, but the homeowner wants to add options to the tub in the future. Which requires him to lift the inner-tub to install on the side of the wall. (Kohler has options to add music, sonic vibration, etc.).
Agree that washing machine hose won’t be my first choice, but I can’t find a technical reason not to! I think a high-quality stainless braided washing mashing machine hose would do the job. I know it is a weird choice!
Old 01-23-2018, 08:24 AM   #11
rrk's Avatar
That is a 2 piece plastic tub, installed one before a real POS, the drain supplied was a piece of flex pipe. Would not pass inspection had to cut hole in the ceiling below or chop up tiled floor.
The supply lines we got with the tub/faucet were white flex lines with plastic nuts, just terrible. People used it 2 or 3 times now it just takes up space.
All of the connections are between the 2 sections (inner/outer) when you put them together you hope they are not pinched.
rrk is online now
Old 01-23-2018, 06:07 PM   #12
tjbnwi's Avatar
Make sure the pipe adapters are for pipe to hose, not pipe to pipe if you use the washing machine hoses.
Old 01-23-2018, 07:01 PM   #13
tjbnwi's Avatar
I know this one gets used every day.
Tub filler, I did not have to deal with the flex hose, no flex connection anywhere on the drain.
Old 01-23-2018, 07:42 PM   #14
rrk's Avatar
I have put in 2 both were sold by Kohler, one we know came from china. No name anywhere on it or box, but had Kohler sticker on it . It was an oval with the cheapest flex drain I have ever seen. Both had tub mounted faucets not floor mounted.
Is that one a 2 piece?
rrk is online now
Old 01-23-2018, 08:19 PM   #15
tjbnwi's Avatar
Yes, it is the Stargaze line. I recall the CoO on this one was Mexico, I know it wasn't China.
https://www.us.kohler.com/us/Stargaz...NT18500008.htm
Old 01-24-2018, 06:05 AM   #16
local2035's Avatar
Trade: Drywall
Well, I told the homeowner Im going with flex copper. He wasnt happy because more T&M and no easy way to add Kohler options later. I went back to my gut feeling as I want to stand by my work and integrity. Using washing machine hose just didn't feel right.
Old 01-24-2018, 06:09 AM   #17
tjbnwi's Avatar
Flex water heater connectors?
Old 01-24-2018, 07:12 AM   #18
local2035's Avatar
Trade: Drywall
Yep, but not long enough.
Old 01-24-2018, 09:18 AM   #19
kirkdc's Avatar
Question:
Does manufacturers installation instructions trump over county codes?
I've never seen this kind of tub so I'm a bit ignorant on the install.
kirkdc is offline
Old 01-24-2018, 09:31 AM   #20
tjbnwi's Avatar
Originally Posted by kirkdc View Post
Question:
I know they do in electrical installs. Not sure how it is written in the plumbing code.
What code do you feel is being violated?
The tub I posted the picture of is in Highlands Ranch CO. No code issues were brought up.
Chicago Cut Brick Veneer Installation sokoleoko Masonry Picture Post 6 05-28-2015 02:50 AM
