Trade: A.D. Contracting & Remodeling LLC.
Kitec Attached Directly To Copper Pipe? No Fittings
New home in Maplewood. The plumber used Pex-Al-Pex (composite). What I found strange is that he did not used any fittings (pex fittings I mean) he used regular copper fittings instead. He sweated small nipples (about 1.5 t0 2 inch) to each side of the elbow, then he slided the XPA over the pipe and crimped it. Same with T's ect....
I was most surprised when the worked passed the plumbing inspection. I checked with IPEX and they only reccommend their fittings (plastic since the brass one are under litigation ) Has any of you ever tried this? I am concerned with long term since the entire home was piped this way, any of you professionals ever done this? Thanks |
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Kitec Attached Directly To Copper Pipe? No Fittings
Got pictures?
Pro Plumber
Trade: Plumber
Re: Kitec Attached Directly To Copper Pipe? No Fittings I need to see some pictures, you can bet if it's not installed by manufactures specs they won't warranty there product.
I will post pictures ASAP,
Trade: General
I have used the kitec products but never tried slipping the tube over copper,i think the dimension won't allow the tube to slide over.Kitec makes in insert sweat fitting that you may be seeing.If you are that curious can't you cut the tube, look inside, then reconnect with shark bite?I personally liked the concept of the kitec with rubber o-rings it's a shame they are being sued.I also think that the plastic fittings were the answer to the problem,it is a shame there wasn't enough time to recover.Pex fittings are under my own personal scrutiny now. I spent a small chunk of money to use the kitec now I can't recoup the money.I am full of skepticism with the whole pex fitting industry,and am finding it hard to believe that one fitting is going to out do the other in the dezincification aspect.
#6 | |
Re: Kitec Attached Directly To Copper Pipe? No FittingsQuote:
Re: Kitec Attached Directly To Copper Pipe? No FittingsLast edited by A.D. Const; 12-17-2008 at 11:33 AM. |
I can't get a proper picture but you'll noticed that the ring is right on the copper pipe. It did pass the plumbing inspection, but has any of you guys ever done this? and if you have have you had problems with it after a while. I am concerned with the lack of the O rings, but then again not all fittings have O rings. Any input will be greatly appreciated.
Trade: Plumbing & Gas Contractor
I don't think it would pass here because the code states approved adapters must be used to join dissimilar types of pipes,but you never know.I guess if it's hard copper you should be ok,but I have seen plenty of soft in walls which would be a no-no to crimp.
The easiest thing to do is go to your local building inspection office, ask to speak with the plumbing inspector for your job. Be polite & listen to him before disputing his reasoning. He may not have noticed the joints, (even though should have), but they have a lot of houses to inspect, typically.
Regardless how well they intend or try to inspect, to an extent they do rely on the professional to do as should. But if questioned you will receive a proper response, if not, speak with the head inspector. If wrong they will contact the plumber, if accepted method, they will better explain to you. Besides, what did the plumber say who did the plumbing??
Proud to help make a house your Home Never judge another by one's own intelligence |
#11 | |
Besides what is legaly binding or "up to Code" I want to know that I delivered quality work, after all that is what my reputation is all about. I want to do the right thing and deliver the right product that's why I am here writing this post. |
#12 | |
In court, (most states you can now drag in the local building inspectors into a law suit) Inspectors cannot be held liable to catch every detail of an inspection, that is the responsibility of the one licensed to perform the needed work. Code is the minimal building standard allowed, as you know. Call the manufacturer and speak with customer service, speak with the code inspector if you want to CYA. A few questions are far better now then to worry or worst yet, recieve that call you wish you had not picked up. ![]() You never know, they may accept it, if so you will have a letter in your files in the event that call does indeed come in. Your plumber's way may work great for 20 years, but if you have doubt a few simple calls can resolve it. One job I inspected after an outlet box had been moved to allow a staircase handrail to be installed. The Electrician did the work far faster than I believed it could have been completed in. I cut out the drywall patch he had a freind do for him to cover the whoe of the old box. With the drywall cut out, I discovered why he did the swap out so fast. He twisted the wires together, used automotive connectors & heat shrink tape for the wire extention needed. hahaha I called him and he assured me, this was an accepted method could do for leaving wires spliced together & burried in the walls. He went on to tell me the head inspector gave him a letter to the fact. Next day I had him meet me on site, along with the H/O & trim guy thee to install the handrail. Funny how he had lost the letter from the head inspector. Then once I went to call the inspector his story changed.. He was just trying to get it done to allow the trim guy to finish. I got a price form the trim guy to change his schedule, deducted that form the electrician's pay due, had him install the new box "per code" and this way I was covered, the H/O was safe, the trim guy was happy & I recieved a bonus for catching this. Be sure, be safe.. Be happy.
Pro Plumber
Trade: Plumber
Thats messed up, no way would that be allowed here.
Trade: General
After looking at the posts and pictures I went back down to my basement where there is a roll of 1/2" and3/4" kitec,I reamed the end of the 3/4 and "AGAIN" the copper did not slide into the Kitec!!!!Those pictures do not show enough copper sticking out of the fitting to make that determination.It looks as though they could still be insert adapters.Whoever thinks all pex brands are the same dimensionally needs to consider if that was the case the fittings would all be universal.Compare uponor to kitec you will definitely see the difference.
Plumbing is a Profession
I can't fnd anything in either IPC or UPC that would not allow this with the exception of the rule about internal ledges and restrictions but these are present on the pex fitting not the copper swett ones.
#16 | |
I wouldn't have faith in the connection with-out a barbed fitting,hope the water pressure isn't that high in the home.I would have to question the guys installation practices,or maybe he was trying to save a trip to the supply house.Either way it's not good.Maybe the inspector didn't realize there were no barbed ends?
#18 | |
Confused |
#19 |
Contact the manufacturers of the specific brand of pipe and see what they say is a good method of adapting to other types of pipe.They shouldn't be too hard to track down.
#20 | |
Al Smith
disclaimer i am not a plumber. But if M, L, and K, copper tube had different OD wouldn't you need different batches of all the common copper fittings? I'm pretty sure its the ID that varies not the OD. |
| Water Heater Connections (Water) - Braided SS, Copper Flex, SS Flex, Hard Pipe? | 22rifle | Plumbing | 44 | 06-08-2008 09:59 PM |
| Copper fittings | wrenchman | Contractor Swap | 0 | 01-20-2008 01:35 PM |
| Cement Contact with Copper Pipe | Capt2 | Plumbing | 11 | 04-17-2007 09:05 PM |
| Copper Pipe, Pin Holes , is it happening by you?? | tzzzz216 | Plumbing | 16 | 11-18-2006 08:48 PM |
| Copper pipe locator | mlsgroup | Plumbing | 3 | 01-21-2006 08:42 PM |
