Trade: Finishing
Kitchen Sink Is Clogged!! Any Suggestions
Okay.. here is the deal.. The kitchen sink is not draining! Double Sink and the side with the garbage disposal drains. I can see water sitting in the p trap if I look in the side without the disposal. The diswasher fills into the sink and the remaining water sits in the dishwasher and overflows onto the floor. I have run a 30 foot snake down the drain and nothing appears to block it. I have used the liquid clog removers and those do not work. Tonight I had to suck water out of the sink and dishwasher with a shop vac. Any suggestions?
Plumber
Trade: Sewer Rat
Re: Kitchen Sink Is Clogged!! Any Suggestions
the dish washer should be hooked up to the disposal side of the drain. you need to call a plumber and fix that or clearing the drain will be an every day thing
Pro Plumber
Trade: Plumber
Check your codes, some codes, state and or local will not allow dishwashers connected to the disposals.
Plumber
Trade: Sewer Rat
Why`s that? I don't understand why you wouldn't hook up there?
Gotta have a place to catch all the food waste from the dish washer. Is it because when the line becomes plugged you can force waste back down in the washer with the disposal |
#5 | |
Trade: Plumber
Re: Kitchen Sink Is Clogged!! Any SuggestionsQuote:
Also, many codes require an air gap between DW and drain, Madi needs a plumber, or might take a peek at the DIY section of this site. |
| Cast Iron Kitchen Sink | KentWhitten | Painting & Finish Work | 7 | 06-28-2007 09:25 PM |
| Bath & Kitchen Remodeler wanted for Upstate SC | SCDreamMaker | Help Wanted or Looking For Work | 0 | 05-23-2007 10:50 AM |
| Composite Kitchen sinks | MikeT | Remodeling | 3 | 10-24-2006 07:31 PM |
| Kitchen Sink Window Height? | thepawnshop | Construction | 6 | 07-01-2006 06:27 AM |
| Sink Garbage disposal will not shut off | smcgowan@msn.co | Electrical | 4 | 06-08-2006 01:16 AM |
