Trade: Plumbing Contractor
Kinked Supply For Roman Tub
any advice on straightening a kink on the supply tube of a roman tube without cutting into the sheetrock?
I was thinking of disassembling the handle and snaking 3/8 pex tube into it, then leaving it there so it doesn't kink again. any other ideas. . . . thanks |
Re: Kinked Supply For Roman Tub
Don't you need an access door in the sheetrock anyhow?
The Grand Wazoo
Only for the pump, the tub filler is probably on the other end.
Geez, and all this time I've been thinkin' somebody might need access to the drain and valve too.
![]() What a waste. Oops, I guess they do!
The Grand Wazoo
We bury both with stone on a regular basis, if it was installed correctly and tests out leak free why the hell do you need access to it? Repairs to the valve can be made from the top side.
They aren't all roman tubs, and it sounds like the OP wouldn't mind a little access right now?
Also seems to be a corollary to Murphy's Law: The harder it is to get to, the more certain it is that you will have to.
#7 | |
Trade: hjrafiuoashfed
Re: Kinked Supply For Roman TubQuote:
It always amazes me why a plumber should care about walls. Git yer single jack and 'ave at it, mate. |
The Grand Wazoo
I guarantee you, on the work we do, the customer is not going to be happy with a removable section of slate or stone in their bathroom. These people pay tens of thousand of dollars for it to be done right the first time.
It's true, I don't work many "Gold Coast" standard jobs,
But it's also true that I design most of my jobs. I work hard to allow for access. Some times you might be amazed (especially with rare earth magnets). I've got a couple of marble platforms that it might take you a while to figure out what piece comes out! But your customers are in a different world than mine. No question about that. (Read, Ø snark level, here)
#10 | |
The Grand Wazoo
All of our jobs have a designer, most have an architect too. It is done the way they want it done. I buried the roman tub filler at my house for that matter.
Trade: Electrical Contractor
I'm with Putty Truck on this one. I have to install conduit in finished homes. I don't care if there's access or not. I can make my own access.
Dave |
Chief Toilet Mover
Trade: Bathroom Remodeling
Guys with the bull in the china shop mentality are the ones who I call as a last resort for jobs. Guys who have finesse and take pride in running wires or pipe with the least penetrations are the ones who get called first. You can and will work as you have been taught and feel you have the right, but we also have the right to pick and choose who we want to hire.
I've heard from talented electricians along the lines that the mark of a good experienced electrician is not having to cut access and the mark of either a hack or a newbie is measured by the repairs they cause. If I have the choice between somebody who can run wire or pipe with minimal repairs or somebody who is going to come in with total disregard I wonder which one is going to get my business? |
#13 | |
Chief Toilet Mover
One more reason why it pays to work with tradesman that exhibit the right qualities.
Trade: Plumbing & Gas Contractor
I've plumbed- in many jacuzzis,roman tubs ,whirlpools,and in very high-end homes.I always stress the need for access.How do you test supply lines anyways,all you're getting is a static reading?Regardless,waste and over-flow gaskets eventually fail.Washers in supply line connections under the deck may eventually fail,especially hot side.The prudent person allows for access.I've even repaired/replaced pumps from the exterior of the home,two stories up a ladder to a access panel on the out-side of the home.Parts fail with no-fault on the installers end and sometimes take a while to show up,better to be safe.We don't plan to fail but sometimes fail to plan!
What are we supposed to do then, Mike? Wiggle our 18" biceps thru a 2" peep hole to repair a 1/2" x 12" flex? Or maybe say a few holy words over it and the demons will depart?
Where's my single jack.... |
Pro Plumber
Trade: Plumber
New install work is good for 1 year thats all you need to know, if you install something and it last better then 1 year you did the job right, chances are it will last many years beyond the warranty period. If everything we put in last a lifetime, there would be no work for us to do.
#18 |
Chief Toilet Mover
No, don't get me wrong, when you have to rip open, you have to rip open.
But I've seen some guys that will rip open a square openning on the face of a corner and I've seen guys who will rip open the entire corner, bead and all, torn up and away, ripped assunder. The first guy opens up a hole and sees if he can work with it, he might have to tear the entire corner out, but he will do that if he has to and not until he is sure he has to. The 2nd guy comes in with the attitude of I'm the plumber, I make holes! and tears the sh*t out of the place tearing out the corner, makes a 10 minute repair into a 2 hour repair, then you're standing there repairing this gaping giant maw wondering what the *****? Did the guy need to be able to crawl inside the wall? ![]() On the electrical side, I've been told many times by great electricians that they take pride in avoiding cutting holes and consider it a badge of honor to demostrate their experience in the trade. I've also seen some that I would consider hacks and the amount of holes they cut seems to be in direct proportion to how much of a hack they are. I had one guy a long time ago cut my sub floor open, right through the hardi backer that was already installed for the tile coming in later. It was the difference from running a wire down from a box 3 feet from the bathtub he was wiring and across the floor or running the wire up the wall and over across the attic and down the wall behind the tub (which was open studs)! That was absolutely ridiculous. |
#19 |
Moderator
Why would you not want some access for inspection or repair? From any point of view?
Are you doing your client a good service by pretending that access will never be an issue or because your warranty period is more likely to expire before there is a problem? The "Looks good from my house" hack is exactly the kind of subcontractor I don't want to hire under any circumstance.
#20 |
I agree 100% about having an access hole. When it's a job I begin, I always tell the customer there has to be one because you never know what might happen.
The situation here is that the entire bathroom is tiled up the butt, and there's no good place to put an access panel without it being in your face. Customer is one of those very picky types. I told the customer that, most likely, I will have to open the wall a bit to fix it. I was just wondering if there were any other options (tips or tricks, etc.) on fixing it. . . . |
| drywall supply place in Central PA | fr8train | Drywall | 10 | 01-31-2008 09:27 PM |
| Contractor only building supply stores. | Michaeljp86 | General Discussion | 2 | 09-12-2007 12:34 AM |
| Supply tubes, who uses what? | gitnerdun | Plumbing | 21 | 11-17-2006 08:29 AM |
| Flushmount Light with MIN 90C Supply Conductors | kpikul | Electrical | 1 | 11-15-2005 06:41 PM |
