Kick Space Heaters Question...
Old 04-03-2008, 02:01 AM   #1
PlumbingPro's's Avatar
Trade: Plumbing Contractor
Question
I have a question on kick space heaters in a boiler system. The kick space heaters have 1/2 connections, the baseboards in the system are 3/4. Is it ok to reduse down to1/2 to go into the kick space heaters and then go back up to the 3/4 once you exit the kickspace heaters? Any help on this would be great. Thanks Guys.
PlumbingPro's is offline
Old 04-03-2008, 08:00 AM   #2
Future Mod...
rex's Avatar
Trade: Master Plumber
Re: Kick Space Heaters Question...
yep ive always done it that way.....
rex is offline
Old 04-03-2008, 09:09 AM   #3
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
do they make them in 3/4 ? just seems like thats what u have to do , just prob loosing a lil bit of heat , but then again you dont need much as a toe kick .
odellconstruct is offline
Old 04-03-2008, 05:47 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Is this a hot water system, a single pipe steam system, or a steam system with a return?
KillerToiletSpider is online now
Old 04-03-2008, 11:31 PM   #5
This is a hot water system, 3 zones. i have 2 kick space heaters on the master bedroom zone under the his and her vanitys. and i have two kick space heaters on the living room/kitchen zone, under the kitchen cabinets. As far as im aware, these only come in 1/2? Thanks for the help guys. I realy appreciate it.
Old 04-04-2008, 05:39 PM   #6
The Grand Wazoo
You can reduce the pipe size, but use bell reducers instead of bushings to ease turbulence.
Old 04-04-2008, 06:23 PM   #7
mdshunk's Avatar
If it's a loop system, you might be better off coming off of it with monoflow tees to the kick heater rather than loop through it. It could be enough of a restriction to make everything after it have reduced performance if it's part of a loop.
mdshunk is offline
Old 04-05-2008, 09:00 PM   #8
I was planning on putting the kick space heaters at the end of each loop. Basicaly, Zone 1, from the boiler, thru the baseboards in the master bedroom, then reduce down as they enter the kick space heaters in the master bath and then back to the boiler. Same on the zone for the living room. Boiler, to the baseboards, then to the kickspace heaters and back to the boiler. As far as using bells vs bushings, im running pex, so im just planning on using the 3/4 to 1/2 pex fittings. Speaking of pex, anyone here use pro pex/ uponor?
Old 04-05-2008, 10:52 PM   #9
Kitchen and Bath Expert
Paul Joseph's Avatar
Trade: remodeling contractor
monoflo t's off the 3/4" branch is the way to do it rather than restrict the entire system
Paul Joseph is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
kick space heaters Eoin Plumbing 1 11-18-2004 06:10 AM
