Issue With Water Abruptly Shutting Off!
Old 12-07-2017, 11:56 PM   #1
Tcnjay's Avatar
Hi fellow Plumbers. I ran across an issue today that I am at a loss of words for. The issue is that half of the house has low hot water pressure and the other half is fine. This is also poly pipe.
When I turn on the hot water on the left side of the house (ie. kitchen sink, bathroom faucet, shower), it runs fine for about 7 seconds and then gets hit with a small shock and hot water flow is reduced to a third. The 7 seconds is further reduced if I keep turning it off and on. After a few immediate on and offs, itís all low water pressure until leave it off for a few minutes.
The right side of the house works completely fine. Itís almost like something is clogged in the pipe on the left side. The water is all coming from the same water heater.
Any ideas!?!?! Iíve been pulling my hair out.
Tcnjay is offline
Old 12-08-2017, 08:56 AM   #2
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 1,702
Re: Issue With Water Abruptly Shutting Off!
Pro advice starts at tree fiddy !
kirkdc is online now
The Following 3 Users Say Thank You to kirkdc For This Useful Post:
Fouthgeneration (12-10-2017), SmallTownGuy (12-09-2017), Unger.const (12-10-2017)
Old 12-09-2017, 12:07 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,393
Draw a plan/diagram of your hot water pipes, the issue is After they split right and left, and BEFORE they split further on the bad side.
If it is "Pex" look closely at the distribution plenum(s)
WAGs 1.0 A bad check valve
2.0 some type of plastic Foreign matter in the hot pipe.....
3.0 A bad pressure regulator?
4.0 A partially crushed or KINKED(poorly installed, here is big money ) pipe that collapses when water flows/ pressure drops.
You could temporary install a garden hose (Hot water rated) if you hook it to a hot sillcock(Laundry faucet?,) between a sink or shower faucet with a hose adapter, then turn on the hot water at that sink, and see if all other fixtures flow "normally"
Good luck,
Post back please with the answer......
Fouthgeneration is offline
Old 12-09-2017, 12:57 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 5,402
Originally Posted by Tcnjay View Post
Hi fellow Plumbers.
Sounds like you should hire a plumber
I can think of more than a few things. Backflush the system into a bucket, map it out, test every faucet in the house, start visually inspecting the system. Start asking questions to the builder/plumber. Is this a new house? Was work recently done to it? Was everything working fine, then all of a suddenly this became an issue?
Peter_C is online now
Old 12-09-2017, 02:47 PM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 430
It's almost 2018, Shouldn't we consider a price increase?
Home Designer Series Software
B.Johnson is offline
The Following 3 Users Say Thank You to B.Johnson For This Useful Post:
Fouthgeneration (12-10-2017), kirkdc (12-09-2017), SmallTownGuy (12-10-2017)
Old 12-09-2017, 05:41 PM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,202
bladder on a bang cartridge blown & being sucked into main feed?
Net Zero Energy Is Here Now
ďThe worst day working for yourself, is still better than the best day working for someone else!Ē
..Jim Rohn
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 12-09-2017, 09:25 PM   #7
tjbnwi's Avatar
Rewards Points: 982
Pipe wall delamenation.
tjbnwi is online now
Old 12-09-2017, 11:11 PM   #8
kirkdc's Avatar
I'd order a colonoscopy
Old 12-10-2017, 11:31 AM   #9
Unger.const's Avatar
Rewards Points: 2,412
Tree fiddy plus expenses
Unger.const is offline
The Following 2 Users Say Thank You to Unger.const For This Useful Post:
Fouthgeneration (12-11-2017), kirkdc (12-10-2017)
Old 12-10-2017, 12:20 PM   #10
Trade: Masonry
TJBNWI: I think you meant "de-lamination" the composite tube of the pipe separating into its components, 'De-lamentation', removal of grief? Or 'delamenation' the end of a country being pitiful?
Old 12-10-2017, 12:52 PM   #11
B.Johnson's Avatar
Trade: Builder
Rewards Points: 430
If I get a vote I'm going with delamenation. Can we make it a poll?
Old 12-10-2017, 01:04 PM   #12
tjbnwi's Avatar
Rewards Points: 982
Wow---somebody does read my posts. I had to close the spell check to pull that off.
Old 12-10-2017, 02:14 PM   #13
kirkdc's Avatar
It's really a pretty good post as I've run into these types of situations in the past.
You really have to play detective, eliminate things and isolate it.
It could be several things as well, not just one.
Old 12-13-2017, 11:32 AM   #14
Tcnjay's Avatar
Update everyone! I went up into the attic and see that the line coming from the water heater splits. One line goes to the middle of the unit (working bathroom) and the other feeds the left side of the unit (clogged side). It goes down into the ceiling from the attic so I am unsure where it starts to T to each fixture. There are 3 fixtures involved with the clog side. A bathroom (faucet and shower) and a kitchen sink.
I did find out additional detail through messing with it.
1) I hear a thud sound coming from behind the bathroom sink when the clog happens.
2) If I leave any fixture on after the clog happens, the other 2 fixtures work fine. It seems like the clog traps the object so it doesnít block the rest.
I am planning on getting a thermal camera to see how the piping is laid out in the unit so I am not randomly opening up ceilings and walls. Any other suggestions to solving this problem?
Tcnjay is offline
Old 12-13-2017, 11:49 AM   #15
kirkdc's Avatar
Any access panels?
Old 12-13-2017, 11:55 AM   #16
Tcnjay's Avatar
No access panels. The bathroom and kitchen are separated by a common wall. On the kitchen side are the cabinets which I would hate to start tearing down.
Tcnjay is offline
The Following User Says Thank You to Tcnjay For This Useful Post:
kirkdc (12-13-2017)
Old 12-13-2017, 12:01 PM   #17
kirkdc's Avatar
What type of water lines do you have ? copper, galv? etc ?
BTW, I'm no licensed plumber-man so proceed with caution.
you quoted :
2) If I leave any fixture on after the clog happens, the other 2 fixtures work fine. It seems like the clog traps the object so it doesn’t block the rest.
1. The thud is just a line banging around due to pressure changes. Sometimes lines don't get archored down properly when installed or then bang off of the holes that were bored out in the studs.
2.Interesting. Hmm. The plot thickens. Is this YOUR house ? or a HO ?
Old 12-13-2017, 12:24 PM   #18
Tcnjay's Avatar
Right I agree. Could not be the problem area. The piping is the old pex/quest piping.
Tcnjay is offline
Cold sqft to Hot water sqft knothead Pressure Washing 6 02-22-2014 01:08 AM
installing ice and water shield in winter manny123 Roofing 24 11-28-2012 06:31 PM
water proofing parkers5150 Masonry 6 10-25-2012 03:33 PM
Extreme water usage for single guy living alone - HELP CarrPainting Plumbing 57 06-30-2012 12:47 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
