Iron In Well Water
Old 07-05-2009, 11:11 AM   #1
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
Iron In Well Water
I am putting up a structure
I dug the well and there is a lot of iron
my question is If they want to irrigate and not turn every thing orange
what would the easiest way to filter or pull that iron out
nailkiller1 is online now
Old 07-05-2009, 11:13 AM   #2
SelfContract's Avatar
Trade: Home Remodeling
Talking
Re: Iron In Well Water
1. Hire cheap Mexico illegals to filter out iron.
2. Sell that iron pieces to China.
SelfContract is offline
Old 07-05-2009, 11:17 AM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
define a lot of iron in terms of ppm
naptown CR is offline
Old 07-05-2009, 11:25 AM   #4
hurtlocker
not sure i have not had it tested yet
Old 07-05-2009, 12:43 PM   #5
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I have high iron, water smell like sulphur and it tastes like a hubcap off a 57 Chevy (never actually tried this).
I am considering a reverse osmosis filter just to make coffee and have drinking water.
Filter is about $200, or you can get a sand filter in line.
Lots you can try. Forget the water softener guys unless your friends with one.
silvertree is offline
Old 07-05-2009, 01:33 PM   #6
Pompass Ass
bwalley's Avatar
One way to deal with high iron content for irrigation purposes is to use a sequestering agent and inject it into the well water as it is being used to irrigate the lawn, that way it will not 'stick' to the house or other items the well water gets on.
They aren't perfect but work pretty well depending on the iron content in the water.
You could also run the water through a water treatment system, but a RO system would be overkill and very expensive for irrigation purposes, plus the RO water may not be good for the lawn.
bwalley is offline
Old 07-05-2009, 01:45 PM   #7
Certified Remodeler
silvertree's Avatar
Nailkiller, try the University of Minnesota website for water questions and answers.
http://wrc.umn.edu/
I went their to find out about septic systems as I now have my first home ever that uses a septic system.
I went before I installed my water softener.
Old 07-05-2009, 03:35 PM   #8
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
Careful which filter you select should you choose to go that route. Irrigation systems can burn up a filter life quickly. Sometimes injection of chemical treatment is the better way to go, but you won't know until it is tested and you know the ppm of the iron.
I have a high sulfur content in my water at home as well, and yes it does taste absolutely awful. Even off of R.O. it just never taste that great. I had my own water tested and a softener made for my water conditions. It knocked out most of the nasty and made it bearable. Iron is nasty the damage it can do to a driveway or exterior wall is a major PIA.
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
Old 07-05-2009, 05:54 PM   #9
The Grand Wazoo
KillerToiletSpider's Avatar
I have a lot of friends that live in the iron range, all of them have an iron bottle of some sort or another.
KillerToiletSpider is offline
Old 07-05-2009, 06:50 PM   #10
Teetorbilt's Avatar
I have the same problem here (iron/sulphur). The easiest way is to configure the system to where water doesn't hit anything. I used low level emmitters around the perimeter of structures and inside planting beds, the bigger adjustable heads outside of that for medium areas and gear heads for the wide open spaces. We get a lot of wind so the RustAid is used about once a year.
There are other ways to include a full blown water treatment system and the injection system which will require 2 pumps if you intend to use the well for other purposes. All of the "injection" systems that I have found are really suction systems with the feeder line going to the pump suction line.
Albert Einstein
Teetorbilt is offline
Old 07-10-2009, 03:11 PM   #11
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
my well has alot of iron, we went with a bleach injector to a contact tank then filters out bleach then water softner -- best water we ever had
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Old 07-10-2009, 04:36 PM   #12
Certified Remodeler
silvertree's Avatar
But does it make good coffee?
Old 07-10-2009, 05:12 PM   #13
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
I have clients with private wells here in NJ (if it's not a house, they call it a public non-transient water supply, and they are regulated), and I do parts of the DEP BSDW reports for their relicensing. I see Birm iron filters in the places I go. In fact that's pretty much the only brand I see. I can't attest one way or the other, but that's what I see.
Aggie67 is offline
Old 07-10-2009, 05:28 PM   #14
Certified Remodeler
silvertree's Avatar
Birm does not work if their is a "Rotten egg" smell. Not recommended for over 10 ppm.
Greensand filters are suggested then.
Old 07-10-2009, 05:38 PM   #15
Proud Plumber
If your question is referring to chlorine injection, the answer is NO. Strictly my own experience and taste. It would be like putting peanut butter on your hub cap. Either way the taste still exist. We use R.O. at the sink for coffee.
Strictly my own experience.
Bill
Old 07-10-2009, 05:45 PM   #16
Certified Remodeler
silvertree's Avatar
After reading a lot on this, including the experts who offer very different opinions, my take is this.
Get a water softener for bathing and laundry, right from the well for outdoor stuff and reverse osmosis for drinking.
Old 07-10-2009, 06:02 PM   #17
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
"It puts the filter in the well"
nEighter is offline
The Following User Says Thank You to nEighter For This Useful Post:
BobsLandscaping (07-10-2009)
Old 07-10-2009, 08:40 PM   #18
Jeff
jkfox624's Avatar
Trade: master turd burglar
Wow for some reason and im not sure why i would of never thought of well water in florida having alot of iron. I kind of always thought that was a northern states type of thing. With the big boom in oil drilling around here everyones having a big problem with iron, manganese and methane in their wells. Couple ppl can light it coming out of the faucet, good times right there.
jkfox624 is offline
Old 07-10-2009, 08:51 PM   #19
BobsLandscaping's Avatar
Trade: Landscaping
On the Polar Sea we had 2 evaps that turned salt water into fresh water. The system was designed so that you could suck raw sewage into it and have clean, safe water. It used steam from the boilers to heat the water in a vacuum, water in a vacuum boils at around 112 degrees. Uses less energy than boiling in atmosphere. The steam that came off the boiling water ran through a condenser where it was cooled and then into a pair of 10,000 gallon holding tanks. Worked great. The reverse osmosis system was constantly requiring maintenance, filter changes, and cleaning. The evap required no real maintenance, just check the pressure and temps periodically.
If you could build an evap you could store large quantities of water in holding tanks, then you wouldn't have to run your boiler all the time.
The evaps on the Polar Sea produced around 300 gallons of water per hour each. Real efficient machines. The boilers that powered them (and heated the living spaces) burned around 75 gallons per hour diesel. We had two of those as well, but could run both evaps off of one boiler.
BobsLandscaping is offline
Old 07-10-2009, 08:59 PM   #20
ampman
ampman's Avatar
yes - yes it does
ampman is offline
Hot water problem PLUMBINGITALL Plumbing 7 01-24-2009 11:15 AM
Water heater right size. flashheatingand Plumbing 0 01-11-2009 03:02 PM
water damage and condensation bigblue General Discussion 2 01-10-2009 01:11 PM
water water everywhere genecarp General Discussion 7 09-07-2008 08:54 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
