Installing Tub And Surround
Old 03-22-2006, 06:53 PM   #1
jcovey's Avatar
Trade: general
Hello everyone,
I am new to this website and this is my first post.
I am installing a new tub with a three piece surround and when I tore out the old tub I discovered the floor is really unlevel. It slopes 2" from drain end to other. Is there an easy way to correct this. I have used shims in the past with moderate success, but if I shim 2" it will look funky when I install trim in front of the tub. any help will be greatly appreciated.
jcovey is offline
Old 03-22-2006, 08:00 PM   #2
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Re: Installing Tub And Surround
Shims.
Looks like some pros were here.
Gordo is offline
Old 03-22-2006, 08:43 PM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
How was the old tub installed? Was it totally screwed up? Put the new one in like the old one.
Mike Finley is offline
Old 03-22-2006, 09:23 PM   #4
Tom R's Avatar
2" over 5'??
Sheesh!!
Way past 'unacceptable'!!
Tear up the subfloor and sister-up the joists!!
If not, - - your neck will be sore from hanging your head in shame!!
http://www.tr-built.com
Tom R is offline
Old 03-23-2006, 04:55 AM   #5
Bjd's Avatar
If you are doing a fiberglass tub, you may be able to scribe the tub skirt and shave some off. However I dont think you are going to be able to pull 2".
BJD
Bjd is offline
Old 03-23-2006, 12:29 PM   #6
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
#1- set level ledgers
#2- bed new tub in perlite(availiable at drywall suppliers)
#3- after allowing to dry overnight finish install as you always would
remember to mix lots of material and simply clean overage that runs out before it dries
#4- you can't be held reponsible for everything as the tub must be level. advise homeowner to install new flooring and hand that ball to them
go dart is offline
