Installing Bath Fixtures In Basement
Old 09-26-2007, 06:56 PM   #1
72chevy4x4's Avatar
I'm looking into the Zoeller Quick Jon system-a pedestal which can accomodate a toilet or other fixtures. It's height is 5 1/2".
My question is, have you seen an install where the floor was framed out so that the entire floor was 5.5" plus a subfloor (IFF possible) on top of the QJ tank? Can the QJ system handle a sink, lavatory and tub? Any other tips for advising a contrator on selling this system?
The cast iron drain (city sewer) is about 3' off the ground-but is very solid. An easy entrance would be to extend the cleanout with another wye and add on the new system at that point, but the downside is the ejector pump would have to pump to a height of 7.5'. Can .4 hp pump handle this or is the .5 pump necessary for the added height resistance?
Would love to hear your recommendations
72chevy4x4 is offline
Old 09-26-2007, 07:12 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Installing Bath Fixtures In Basement
I can give you an opinion, sawcut the concrete and put an ejector pit in.
Those Zoeller tanks have a tendency to crack, or get a screwhole through them from installing the subfloor.
KillerToiletSpider is online now
Old 09-26-2007, 07:23 PM   #3
72chevy4x4's Avatar
thanks-that's what I'm thinking is needed b/c of height issues.
I've never cut concrete out of a basement before-is there an easy way such as relief cut half way through and jack hammer or just go for the gusto and cut the whole thing out? Is there a method that creates 'less' dust? That would be the biggest issue I can see from this install.
If there is a 4" vent from the first floor out the ceiling-is it w/in code (generally speaking) to tap into that or must it be a straight shot w/out to many bends present?
Old 09-26-2007, 07:32 PM   #4
The Grand Wazoo
My concrete saw has a water attachment, it's a mess anyway you look at it, but slurry is easier to clean than dust, and I through cut floors.
I don't know code in your area, but here you can can vent the ejector pit in 2", and tie the W/C, lav, and tub vents into that, the number of fittings makes no difference as long as the vent is not trapped.
Old 09-28-2007, 12:28 AM   #5
Grumpyplumber's Avatar
Trade: Plumber
I agree, not to mention the cost offset isn't worthwhile.
Sewage ejector is the best longterm solution.
Grumpyplumber is offline
Installing Customers Fixtures - Plumbing kimbleplumbing Business 2 04-11-2007 10:19 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
installing basement windows in concrete blocks mtpgoat Remodeling 2 03-25-2006 10:06 AM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
Installing New Basement Windows...(help!) bluethumbnail Windows, Siding and Doors 3 11-05-2005 11:04 PM
