Inspector Woes
Old 07-11-2007, 10:31 AM   #1
PARA 1's Avatar
Trade: PLUMBING
Inspector Woes
ON JAN 07 PULLED OFF A JOB BECAUSE OF HOMEOWNER ISSUE'S[MONEY] NEVER GAVE IT A SECOND THOUGHT ....JULY 07 GET FAX FROM INSPECTOR SAYING...NEED TO CORRECT TURN DOWNS OR FACE FINE ...WROTE LETTER TO CITY HALL IN DETAIL AS REQESTED TO CANCEL PERMIT GOT FAX BACK FROM INSPECTOR SAYING ALL TURN DOWNS MUST BE CORRECTED. WHAT THA!
PARA 1 is offline
Old 07-11-2007, 11:00 AM   #2
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
Re: Inspector Woes
Well I am sorry the home owner was screwing with you however, you have done work that a permit was pulled and inspected so there for the work you have done has to be up to code and then you may cancel the permit. At least that is the way we deal with it here.
Good Luck
Justin
Moscow is offline
Old 07-11-2007, 09:44 PM   #3
JamesNLA's Avatar
Trade: Plumbing & Electrical
Re: Inspector Woes
You should have to fix it. You don't get paid to bring YOUR work back into code. Why should the home owner have to pay twice for the same job. That said, this brings up an interesting thought (for me at least). If the HO stiffed you for all or part of a section of the job....say Rough drains. The inspector fails the drain install, would you THEN still be obligated to fix it?
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 07-11-2007, 10:14 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Inspector Woes
You should go back and fix it for not pulling your license from the job when you decided to leave it.
KillerToiletSpider is online now
Old 07-11-2007, 10:19 PM   #5
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Re: Inspector Woes
You mentioned money issues. Did the homeowner ever pay you or intend to not pay you for the work?
In_Mexifornia is offline
