Increasing Water Pressure And Volume?
Old 02-02-2009, 12:00 PM   #1
Haydin's Avatar
I was at my brother in laws last night. He's been working on an old less than ideal owner/builder house he bought a couple years ago. Needless to say there have been more than enough headaches with renovations. One of the major upgrades has been new 5/8" (??? size stamped on line) White PEX plumbing throughout. Problem is that the house sits high on a hill and has poor water pressure. For sake of discussion lets say 30 PSI. The current projects is installing a roman tub. Realizing that it would take quite some time to fill at his current pressure, he's looking for solutions. So, for the pros here, I would like to get some feedback on alternatives: 1. would it help to take the 5/8" line and constrict it down to accelerate the water? I believe they do that in Europe? 2. are there local boost pumps that would work? or is adding one to the whole house the better cost efficient alternative. 3. any other suggestions? Thanks, Karl
Haydin is offline
Old 02-02-2009, 12:11 PM   #2
SelfContract's Avatar
Trade: Home Remodeling
Cool
Re: Increasing Water Pressure And Volume?
3. Pump up to a reserve tank (above roof) and pipe down.
SelfContract is offline
Old 02-02-2009, 01:02 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
The easiest solution.
KillerToiletSpider is offline
Old 02-02-2009, 10:57 PM   #4
ct plumber's Avatar
Trade: plumbing2heating
I like the goulds booster pumps that sit on a small holding tank,they dont run every time you need water like those with out tanks,i think they cost around $600
ct plumber is offline
Old 02-05-2009, 03:40 PM   #5
plumber1a's Avatar
Trade: plumbing
You can't simply reduce the size to gain pressure as all you have done is decreased to volume, if anything you want to increase the pipe to cary more volume. A holding tank at a higher elevation would work or a booster system having enough bladder tanks to meet the demand would also work.
plumber1a is offline
Old 02-07-2009, 11:47 PM   #6
jayson22's Avatar
Trade: Plumbing & Heating
I agree completely. Reducing pipe size does cause a temporary increase in the velocity of the water, but in turn decreases the volume and the pressure. I would suggest a booster pump as well since storing the water at a higher elevation is only ideal if it is quite elevated, since water pressure is gained at a rate of approx. 0.433 psi/vertical foot.
I have only installed big booster pumps in high rise applications, but never for residential applications so I can't say which is better between the booster that stores water in a tank or just one that works off a pressure switch but one of the two is the only way to go imo.
just my .02 cents
jayson22 is offline
Old 02-16-2009, 01:32 AM   #7
Joemel's Avatar
Trade: Power Jack Foundation Repair
Try using water pump booster system, this will rapidly accelerate the water pressure, I guess it is one of the best options you may have.
building a french drain maybe a mind numbing task but you can just leave it to the experts~
Joemel is offline
air in lines after work done/air volume diaphram ? bugdoc@linkny.com Plumbing 2 01-28-2008 03:26 PM
Needed: Hot H20 for Spa fred lupton General Discussion 7 11-29-2007 08:35 PM
advice on low pressure well problem 72chevy4x4 Plumbing 0 07-16-2007 07:54 AM
How would you install the plumbing to maximize water volume and pressure in this bath Mike Finley Plumbing 13 03-31-2007 09:49 PM
The Stupidest MSDS you have seen CGofMP Health & Safety 9 03-23-2006 10:33 AM
