Increasing Pump Pressure
Old 02-24-2007, 07:17 PM   #1
Teetorbilt's Avatar
I have an AO Smith, I HP, 230V pump (Goulds #J06853L) controlled by a Furnas series C AS4FX switch set at 30-50.
All of the components are less than 4 yrs. old and have been rigorously maintained. The layout is; pump to 25 g. pressure tank to 30m. filter to Kineteco green sand to WaterBoss 900 softener to 5m. filter to house.
The flow and pressure are less than I would like. Can I safely take this setup and go to 40-60 (I know how to adjust the switch). Will the pump take it? Any idea of how much more it will cost over the span of a year? Kids are gone and the're just two older folks living here but the sprinklers are on the same system. I'll be redoing the sprinklers soon, going to xeriscaping.
Albert Einstein
Teetorbilt is offline
Old 02-24-2007, 08:08 PM   #2
POOLMANinCT's Avatar
Re: Increasing Pump Pressure
generally a larger filter on the effluent side while buy you more flow...
that pump/motor is capable of 1.25hp SF (service factor)
this is the type of ? id throw at you, dont you have a background in fluid engineering? if so id like to pick your brain sometime...
POOLMANinCT is offline
Old 02-24-2007, 10:40 PM   #3
Teetorbilt's Avatar
POOL, sometimes there is something known as too much knowledge. Yes, I could spend a few days, maybe a week determining every detail of a common well system.
I have a finite element anylisis program on my work station that would detail every stress, possible failure and time of failure if I had the time to input the info. I'm looking for the simple way out.
Albert Einstein
Replacement pump for pressure washer T bone Pressure Washing 5 08-01-2008 12:56 PM
advice on low pressure well problem 72chevy4x4 Plumbing 0 07-16-2007 07:54 AM
4 Sale: 1/2 HP Wayne Porta Pump Terrence Pressure Washing 0 04-18-2007 10:43 PM
Irrigation pump pressure switch mdshunk Landscaping 10 12-04-2006 09:39 PM
Well Pump Depth Question... thepawnshop Plumbing 9 08-13-2006 09:01 PM
