Immovable Anode Rod
Old 04-13-2005, 11:49 AM   #1
diezeldawg's Avatar
Trade: demolition
Immovable Anode Rod
I've wrenched so hard its moving the heater. Ive used wd-40 and still no luck. Shound i try a small torch? Whats my next step. I'm not a plumber. So I dont have any tips.My field is demolition. Thank you
diezeldawg is offline
Old 04-13-2005, 06:15 PM   #2
Electrical & Plumbing
Atricaudatus's Avatar
Trade: Electrical and Plumbing contracting
Re: Immovable Anode Rod
Dawg,
I'd be reluctant to put a torch to it. I use a 1/2" drive craftsman rachet handle and have never had one I couldn't break free. Try slipping a short pipe over the wrench handle to gain more leverage. WD-40 is a good lubricant, but a lousy penetrating oil. Try PB Blaster, or liquid wrench. Apply the stuff, let it sit several minutes, then whack the fitting good and hard, then try the tool again.
Good Luck.
-Rhett
Licensed electrician and plumber
Atricaudatus is offline
Old 04-13-2005, 10:09 PM   #3
Teetorbilt's Avatar
diezel, with a name like that you should be able to get your hands on an impact wrench. My choice for stubborn parts.
Albert Einstein
Teetorbilt is offline
Old 04-13-2005, 10:32 PM   #4
PipeGuy's Avatar
Trade: underground
Couldn't be truer :Thumbs:
PipeGuy is offline
Old 04-14-2005, 12:56 AM   #5
Teetorbilt's Avatar
W=water, D=displacement, 40=their 40th try at achieveing the first 2.
It is not a penetrating oil, rust preventative or any other type of snake oil. I learned this in the 70's when it ruined $14K worth of collectible rifles.
Albert Einstein
Old 04-14-2005, 07:11 PM   #6
Thumbs up
Yeah, I gave up on WD40 long ago. Used Liquid Wrench for a while with moderate success, and have since began keeping a can of PB Blaster on all my trucks. A mechanic friend turned me on to it. It reeks like kerosene, but its performed pretty well on some very corroded and seized up threaded parts. It's also a very good preservative for metal tools, leaves an oily film behind. I use it on my fish tapes, pipe cutters, plier joints, tool box hinges, and almost anywhere two pieces of metal rub together. :Thumbs:
-Rhett
Old 04-15-2005, 11:31 AM   #7
diezeldawg's Avatar
Trade: demolition
thx I'll give it a shot
