Ice Maker Hose ??
Old 05-14-2011, 11:57 AM   #1
kdcon's Avatar
Trade: Concrete
Ice Maker Hose ??
Hi, I'm a concrete contractor so I figured I would ask the plumbing experts this question. I need to replace the feed hose to the icemaker on the refrigerator. I have had 2 of the clear hoses split and do not ever want that to happen again. Would prefer a flex type hose if possible. What would you guys recomend ? Thanks, kdcon
kdcon is offline
Old 05-14-2011, 12:02 PM   #2
Life Apprentice
mehtwo's Avatar
Trade: Plumbing & Carpentry
Rewards Points: 558
Re: Ice Maker Hose ??
Is your ice maker on RO water, soft, or tap water?
Don't make excuses, make it happen!!!!
mehtwo is offline
Old 05-14-2011, 12:20 PM   #3
melter of solder
Sharkbiter's Avatar
Trade: Plumber
Rewards Points: 25
Make sure that it is cold water running to the icemaker, that clear vinly tubing is not rated for hot water. I like to use copper tubing, but those 1/4" flex connectors work good too.
Sharkbiter is offline
Old 05-14-2011, 01:31 PM   #4
kdcon's Avatar
Trade: Concrete
I'm on well water that tests right in the middle.
Yes it is hooked to the cold water supply.
Any type / brand flex hose ? stainless ?
Trying to remember to bring a bag of ice home sucks. Going back out to get one cuts into my cocktail hour
Thanks for the replies, kdcon
kdcon is offline
Old 05-14-2011, 01:39 PM   #5
melter of solder
Sharkbiter's Avatar
Trade: Plumber
Rewards Points: 25
I like the stainless steel braided flex lines, as far as brand goes what ever you can find should be ok. Just hook it back up with a flex, make sure it does not leak and forget about it.
Old 05-14-2011, 05:10 PM   #6
kdcon's Avatar
Trade: Concrete
I'm on it Thank you very much kdcon
kdcon is offline
Old 05-15-2011, 01:07 AM   #7
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
Do you give anything?
Or just take?
Otherwise, you don't belong on this site!
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 05-15-2011, 08:57 AM   #8
kdcon's Avatar
Trade: Concrete
Or just take?
I will give what I can. When I see a persons question has been answered w/ the right advice i do not feel the need to post just to throw my 2 cents in. There are a lot of very savvy people on this site who are confident enough to give advice without the fear someone may steal their secrets. The best use of knowledge is to pass it on.
Over the last 46 yrs. I have taught hundreds of youngsters my trade and when they would eventually go on their own I wished them well.
If you have a question you would like answered about concrete ask it and I will do my best to provide an answer. kdcon
kdcon is offline
Old 05-15-2011, 05:03 PM   #9
Rewards Points: 538
Kdcon, my words were uncalled for. I apologize for calling you out. It was a late night.
Very nice response.
Facebook
The Following User Says Thank You to William James For This Useful Post:
aptpupil (05-16-2011)
Old 05-15-2011, 07:27 PM   #10
kdcon's Avatar
Trade: Concrete
Very nice response.
We all have had those Days/Nights. Have to have a real tough skin to be a Contractor and yet sensitive enough to care. As a Concrete Contractor I was about to ask for your shoe size kdcon
kdcon is offline
The Following User Says Thank You to kdcon For This Useful Post:
Tinstaafl (05-15-2011)
Old 05-15-2011, 09:29 PM   #11
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
I use copper supply lines.
see ya!
Mike's Plumbing is offline
Old 05-16-2011, 05:51 AM   #12
Life Apprentice
mehtwo's Avatar
Rewards Points: 558
I would recommend copper as well except for RO, I understand that RO water will corrode copper over time.
mehtwo is offline
Old 05-16-2011, 11:37 AM   #13
Rewards Points: 538
I have used the type of plastic supply you're talking about a dozen times with no problems (not that that's a lot, but..). Where is it splitting?
The causes for splits leaks I've seen or heard of are from pulling/scratching the line through a hole, mice, using a brass Ferrell (under the nut). If it's at the connection then use a plastic Ferrell and you should be fine.
Copper coil would be a better choice in most cases though.
That's funny and scary at the same time.
Facebook
Hitachi Air hose ApgarNJ Tools & Equipment 17 04-23-2010 04:14 PM
Tip for cleaning a used AIRLESS HOSE MZ-HANDYMAN Painting & Finish Work 17 10-03-2009 04:17 PM
Blasting hose questions? edjohnson Sandblasting 17 12-27-2008 06:40 PM
Hose Reels killzoneq2 Sandblasting 4 05-07-2008 07:52 AM
