Trade: Former Electrician
How To Slip Poly Onto The Poly Barb Connectors
As I mentioned in a another post, I have a real hard time slipping the poly tube onto the barb, so I used a very small amount of silicone to help ease it on. I have since read that you should never use any type of lubrication to as I did. I'm guessing that there is a chance that the use of some chemical lubicants could effect the poly. So far they have no tendency to slip off or leak even after I pull on it and wiggle it back and forth a bit. I know a lot of these general guide lines are just that very general. I'm wondering if this is one of them. I could imagine if one were to dip the end into a can of motor oil or spay it with a bunch of WD40 future problem could ocurr, but what about a small application of silicone to the barb rubbed on with a paper towel. I myself am not going to dig any of this pipe back up and certainly will not lose any sleep over it. I'm just wondering what you guys have to say about it.
Thanks Rob |
Plumber / Carpenter
Re: How To Slip Poly Onto The Poly Barb Connectors
if you used the proper fittings, they should not need to be forced on. Sometimes people confuse Quest fittings for pex fittings. The 2 have slightly different inside diameters.
#3 | |
Re: How To Slip Poly Onto The Poly Barb ConnectorsQuote:
Rob |
Plumber / Carpenter
Actually I picked it up off the net, had to do the traditional "Plumbers Butt Crack"
I also just remembered that when I use red pex pipe it does seem to be a little snugger that others, but still is not a problem |
The Grand Wazoo
Are you using black poly pipe or PEX?
If it is black poly pipe, a little vegetable oil on the insert fitting works wonders.
Future Mod...
Trade: Master Plumber
heat it up a little bit with a torch...if your talking about the black poly for irrigation
Plumbing/Mechanical Insp.
Trade: plumbing/mechanical/building inspector
Re: How To Slip Poly Onto The Poly Barb Connectors |
soften it w the heat, knock the fittings in square.
dont torch the pipe so bad you have "scar tissue" & let it cool before cranking on the clamp. btw why did you give up on the pcv? id think it would be cake for a former sparky's conduit skills? ray
......Less with the jaw & More with the paw..... |
The PVC is real easy to work with, but I was getting tired of glueing and also ran out of pipe so I figured I'd try some poly. It's been a long time since I did electrical work for a living and I forgot how tedious this can be.
Trade: master plumber/owner
I'd hate to dig through my tools to find my dusty torch just to get some fittings together so I can crimp them. I would not think vegetable oil would harm the pipe. I use ky just because I always have it handy and it's safe on rubber. haha just joking
, but I bet it would work great
#12 | |
Electro-Mech. Contr.
Trade: Mechanical Contractor
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Trade: plumber
I use to race road race motorcycles for a hobby and I crashed my bike in the 1st race of the weekend and was spose to race in 2 other classes. I had to replace my left clip (left side of handle) couldn't get the rubber grip to go on and some old man and woman were walking through the pit area and seen me struggling with this and the old lady opens her purse and hands me some KY jelly to lube the rubber for I can slip it over the bar. Kinda freaked me out a little. Later that weekend I ran into those old folks again. Of course you with some of your buddys and thay yell out "Hey sonny how did that KY jelly my wife gave you do for you???"
Boy did I get some looks from my racing buddys.I sure miss those days! |
Trade: Plumbing
I carry a heat gun for poly pipe. And for pipe thawing. I move the heat gun a lot so as to not heat it unevenly. You don't want it to melt, but you want it soft enough to slide on. You have to heat it slowly enough that it will heat through.
| poly urethene | donb1959 | Painting & Finish Work | 3 | 01-29-2007 11:37 PM |
| tinted poly | Alkyd | Painting & Finish Work | 5 | 12-12-2006 10:00 PM |
| Oil base or water base poly? | jhf469 | Flooring | 4 | 11-24-2006 11:36 PM |
| Slip Sheet? | Spot | Ceramic & Stone Tile | 2 | 06-23-2006 10:04 AM |
| Deckorators connectors | RobertCDF | Landscaping | 0 | 11-26-2005 11:31 PM |
