Trade: renovator
How To Locate Hidden Water Meter?
Gentlemen,
I gotta find the water meter in this house. Usually a simple thing, but: - there's no basement, only a ~12" crawlspace that is completely enclosed with a concrete foundation all the way around. - I suspect that either it's under the floor somwhere, in the crawlspace, or previous renovators have closed it in a wall cavity somewhere. I do have access to a main shut-off valve through a 6"x6" access panel in a wall in the groundfloor bathroom, but can't see any meter in there. Anyone got a good trick for locating this sucker without ripping up floors and opening walls? Thanks. |
Sean
Re: How To Locate Hidden Water Meter?
Call the water company - they know where its at
Also you can call dig safe & follow the paint - its probably out by the street (at least around most places I have been at) Your location - can you put in your profile? Thanks |
Trade: renovator
Good idea. Well, they sort of almost know approximately where it's at. On the west wall, somewhere between 5 and 15 feet from the north wall. The last guy drywalled that all in. Great. I guess at least now I know which wall to open up...
Trade: GC/Remodeling
hey bob, Around here, a 'main shutoff' valve is all that is inside.. The 'meter', is outside closer to the city line.
edit...read your last post.. how about listening for the meter?
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein Last edited by TimelessQuality; 02-11-2009 at 02:33 PM. |
Trade: Squirrel Handler
Make sure there is a water meter (tons of houses out here without them), the water may have been hooked up before they began charging, check with the homeowner and see if they get a bill and if they do, is it metered, if there is a meter, is there a unit outside to read it, if there is you might be able to trace the wire back. Other than that maybe some small holes and a Milwaukee or Ridgid inspection camera.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Trade: plumbing
Had a similar situation where a defective pressure regulator was buried, dug up and followed the main till we found it.
Look outside along the front property line it may be in a meter pit.
Trade: renovator
Ya, like I said, it's definitely in the house, on the west wall. I like the inspection camera. Off I go...thanks everyone.
Trade: Exterior Remodeling Sales
How about using Thermal Imaging camera?
The Grand Wazoo
That right there will guarantee that no plumbers will reply.
#11 | |
Professional Instigator
Re: How To Locate Hidden Water Meter?Quote:
Might be cheaper to just rip the entire suspect wall out, unless he happens to have a thermal imaging camera lying around.
+1 for SLS. Somebody has to read it and they know where it is. Here, it's in the right of way and spudded as close to the property line as possible. From there on it's all up to the PO.
Same applies to sewer connections.
the pipe master
Trade: plumbing, solar
turn on all of the water in the building. Use an audio leak detector or a good stethoscope to scan the ground and walls. You will hear a "clickity clickity clickity" sound of the gears in the meter spinning like crazy. I use that technique to locate hidden non-metallic water mains all the time.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
Trade: Residential Remodeler
Wait for the meter reader to come by and follow her. She should lead you right to it.
Sorry. I couldn't stop myself. |
the pipe master
Love the avatar!
| The Following User Says Thank You to protechplumbing For This Useful Post: | Brock (02-18-2009) |
Hook a hose to the out door water spicket.
Tie a metal hanger around the end of the hose attached to the sprayer. Drag the hose in the house and walk from room to room the the hanger will pull and be attracted to the water meter Last edited by rbsremodeling; 02-18-2009 at 10:21 PM. |
#18 |
the pipe master
You forgot to mention the step where you ingest psychedelic mushrooms first.
| Flow meter (to measure gallons used) | im4snow | Plumbing | 6 | 11-16-2008 08:26 PM |
| water meter | zed75 | General Discussion | 3 | 04-23-2008 11:48 PM |
| Water heater smell. | silvertree | Plumbing | 6 | 03-29-2008 11:12 PM |
| Water Meter noise | MSSI | Plumbing | 4 | 03-17-2007 05:45 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
