Trade: painting
Hot Water Tank Question
I cannot find any info on why I must drain some of my hot water tank (gas) in order to get it to fire up. If I want a hot shower, i need to call home and get someone to run the dishwasher before i get home. Someone told me it was a required energy feature like an automatic vacation switch (if your not using it, its not going to heat again) and to let the hot water always trickle somewhere.
Can anyone please lead me to the reason. Is it something I can adjust or fix? Thanks Tom |
Trade: Plumbing
Re: Hot Water Tank Question
You should probably call a plumber to come to your house and help you out.
Trade: interior remodeling
Could be several things---
The thermostat may be defective-- You may have so much lime and crud in the bottom of the tank that the thermostat probe is buried --does your tank gurgle and pop? |
Trade: Construction
Sounds like your thermostat either needs replacing or adjusting. They can loose sensitivity after a while.
Trade: painting
tank does not seem to make any gurgling sounds. It is about 10 years old. I tried flushing out the tank. It seemed to be very clean, which surprised me for a hard water area. This has always been an issue, but now it happens more frequently. Before it only happened if we were away for a couple days.
I appreciate all the advice. Tom |
The vacation setting is on your temperature dial. (Near the bottom of the heater) Until more of the plumbers chime in here, have you looked at the dial to make sure it wasn't inadvertanly turned to warm or vacation?
KillerToiletspider usually checks in alot and I would obviously defer to him or other plumbers here, but it might be worth a look.
220...221...whatever it takes! |
Trade: painting
I am certain it is not the temperature dial accidently knocked to the vacation setting.
Trade: Plumbing company
You should call for a plumber like Plumbermurrieta in California the one that you can trust for it.
#9 | |
Trade: http://www.a1plumbers.com
Re: Hot Water Tank QuestionQuote:
Hello good suggestion I am agree with you Regards Jimclemmer
Plumbing Maintenances |
Trade: painting
I have replaced the tank with a 50g that works perfectly. Now I can take hot water for granted again.
Still curious about what the problem was. All I can think of is an overheating sensor shutting off the system, until there is a shift in the float. Tom |
#11 | |
The Grand Wazoo
The Grand Wazoo
Disregard my previous post, you have fixed the problem.
Trade: licensed plumber
You are getting temperatures at showers, then this would not be a water heater issue. There may be a problem in the plumbing.Contact a local plumber to come out this problem.
| water damage and condensation | bigblue | General Discussion | 2 | 01-10-2009 01:11 PM |
| Water heater supply question | bob14-0 | Plumbing | 3 | 05-22-2008 10:22 PM |
| water line question | amurrell | Plumbing | 15 | 05-20-2008 09:44 PM |
| Water Softner Question? | CC1 | Plumbing | 2 | 05-19-2006 05:53 PM |
| Expansion tank on water heater | Teetorbilt | Plumbing | 5 | 04-17-2006 01:53 PM |
