Hot Water Gets Really Hot When Someone Flushes The Toilet.
Ever since we moved into this house. We have noticed a few issues. Most of them I have resolved. I am down to my last few.
For some reason. If someone is taking a hot shower, anything else in the house that requires water is turn on. We get a really HOT shower. I am guessing this has to do with line size. Background house built in 1986 on its own well expansion tank seems small. Then again I am not a plumber. Hot water heater is rather large, and works well. Water pressure at the water tank is 60 psi at the highest. and falls to around 40 or a little better when the well is turned on. All the plumbing is very centralized in the home. Is their anything that can help this out. |
Re: Hot Water Gets Really Hot When Someone Flushes The Toilet.
Sounds normal to me.
Maybe a new shower diverter that has an anti - scolding protection .
Insert title
Trade: Doors-Windows-Decks
I'll give my 2 cents until Ron the Plumber comes in and clears this up. I lived at a place with low water pressure and we had the same issue. My present house has good water pressure and we do not have an issue, run all the faucets and flush without messing with the shower.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
md's right. I'm on a well and experience the same symptoms. Getting used to it is much easier than fixing it.
Trade: General/Plumbing Contractor
Replace the shower valve with a new pressure balanced one, like a Moen Posi Temp for example, good luck.
Trade: Residential and Commercial Remodeling
Re: Hot Water Gets Really Hot When Someone Flushes The Toilet. |
#8 | |
Pro Plumber
Trade: Plumber
Re: Hot Water Gets Really Hot When Someone Flushes The Toilet.Quote:
Pressure Balance or Posi-Temp are requried by code, one other thing you can do if you have access to the pipes below and don't want to replace the valve, there is a inline Pressure Balancing Spool you can get has two ins and two outs, this will fix that problem. Other thing to do is don't use other fixtures when taking a shower
| Is everybody using the toilet gaurd to keep subs from peeing in the toilet? | Mike Finley | General Discussion | 38 | 03-17-2008 10:36 AM |
| Toilet Challenge | Vermaraj | Plumbing | 40 | 11-09-2007 09:04 PM |
| Toilet Problems | McCall Builders | Plumbing | 4 | 01-31-2007 08:24 AM |
| Hot Water | Joewho | Plumbing | 13 | 11-17-2006 02:39 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
