HELP - Power Vent Not Tripping Vac Sensor
Old 02-04-2010, 08:47 PM   #1
TimPa's Avatar
Trade: residential/commerial remodel, woodworking
on my sons hot water heater - reliance 606. i can activate it by sucking on hose. i don't have a manometer so gonna' rig one with plastic tubing and water to see if fan is pulling -0.85 pv as best i can. going to try blowing out filter on bottom of firebox with air gun. see if that improves fan op. any other suggestions? vent is open, about 7' long with about 4 ells and a 45 3"pvc. i'll have to cut it to get the blower assy out.
TimPa is offline
Old 02-04-2010, 09:31 PM   #2
BCConstruction's Avatar
Trade: Construction
Re: HELP - Power Vent Not Tripping Vac Sensor
Perhaps a faulty pressure switch. I have never worked on one or seen one so im not much use.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is online now
Old 02-05-2010, 08:28 AM   #3
TimPa's Avatar
so i made a u tube manometer with plastic hose and water, and measured the fan to be pulling about 2.5" w.c., sucked on the hose to the pressure switch and it required about half that. put it all back together and it started working. i hate that.
TimPa is offline
Old 02-05-2010, 01:04 PM   #4
Trade: Construction
I used to service combi boilers and system boilers and they used to do that all the time. Pretty common to open them up and mess with connections then the things fire back up when you put them together. Pressure switch may have just been stuck and you lossend it up a little.
Old 02-21-2010, 05:16 AM   #5
Plumbermurrieta's Avatar
Trade: Plumbing company
Check the vent pipe where it exits the house. If you can shine a flashlight into the pipe, look for obstructions such as wasp nests etc which can reduce the air flow enough to prevent the switch from tripping.
Plumbermurrieta is offline
What vent hood for custom wood hood vent?? jcs1984 Kitchens & Baths 6 12-15-2009 07:52 PM
Trailer Heaters and Power jakejorgenson Tools & Equipment 3 12-10-2009 11:28 PM
Rheem FVIR power vent water heaters Sewerologist Plumbing 11 02-19-2009 01:24 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
Power vent vs. electric water heater. osborn Plumbing 8 03-02-2007 11:04 AM
