Thom
Help With A Moen Shower Valve
Was at my mothers for Christmas and she asks me to fix a Moen shower valve.
The valve rotates smoothly. It does not pull out at all. The water doesn't turn on. It hasn't been used in 3 years (at least). What's the problem? |
Steve
Trade: Remodeling and Custom Cabinets
Re: Help With A Moen Shower Valve
Did around the Moen web site for exploded views. In my area calcium buildup is what kills most of them. Blocks the passageways up.
Pro Plumber
Trade: Plumber
Replace the cartridge, or there is valves in the off position that is causing it.
Trade: Plumbing
We have this problem from time to time with new houses that sit on the market for a long time before being sold. Lots of time we just take the handle off and tap on the cartridge stem and it will cause the hard water buildup or whatever is in there to break free and the faucet will work great. Other times we just have to replace the cartridge.
Handle It!
What?????????????
No "call a Plumber" statements here??????
Pro Plumber
Trade: Plumber
Re: Help With A Moen Shower Valve |
Handle It!
#8 | |
Handle It!
Re: Help With A Moen Shower ValveQuote:
The New and Improved Ron!!
The Grand Wazoo
Call a plumber.
There, are you happy now Malco?
Handle It!
Re: Help With A Moen Shower Valve All I ask is CONSISTENCY! Anything less could be considered "Bias" or "Discrimination".
The Grand Wazoo
I try to stay consistent.
Plumbing is a Profession
Trade: Plumbing & HVAC
What you have to do is pull the handle, cap and escution then the clip that holds the cartridge. Then take a pair of Vice Grips, grab hold of the brass end and pull and wiggle untill it breaks off. Next step is to get an 8lb. hammer and beat the living bejeezus out of the piece of crap and then Call a Plumber to replace the whole valve.
Moen Strikes Again ![]() (fillin in for ya Ron) |
#13 | |
The Grand Wazoo
#14 | |
with the main turned off?
Trade: PLUMBING/ MECHANICAL LIC SC
turn main water off, take stem out and check for any obstruction. If you don't see anything, with the stem out turn the water on and see if water comes out. (make sure shower door is closed) If the water does then replaced the stem. If no water comes out it might be best to call a plumber.
Pro Plumber
Trade: Plumber
If it's a moen troll valve, could be the balancing spool. You find this on the right side of the valve body, large straight slotted plug, unscrew it and there you will find it.
The Grand Wazoo
If it was a troll valve wouldn't it be living under a bridge?
#18 |
Pro Plumber
Trade: Plumber
Send in the goats.
#19 |
Indulge me a little bit... don't Moen shower valves have little screwdriver operated shutoff valves if you take off the escutcheon? ...or is that some other brand? Just wondering. I remember commenting to a builder that I thought it was odd that there were no valves or access panel to a new shower being built and he related that it had screwdriver shutoffs behind the escutcheon built into the valve.
#20 | |
Pro Plumber
Trade: Plumber
| Stacking (Tub/ Shower valve) | plumbsharpWA | Plumbing | 2 | 03-24-2008 10:51 PM |
| grohe shower valve | fast pasquale | Plumbing | 6 | 07-11-2007 09:36 PM |
| Face Plate for Shower Valve | kpikul | Plumbing | 7 | 01-27-2007 08:35 PM |
| Replacing a shower valve. | Leo G | Plumbing | 3 | 09-09-2006 03:04 PM |
| Question about shower system... | Knyte260 | Plumbing | 59 | 10-24-2005 06:05 PM |
