Heat Exhcnager/ After Cooler
I am looking for a aftercooler for my air compressor.
Air to air aftercooler with threaded ends. Does anyone know where i could find these? |
Re: Heat Exhcnager/ After Cooler
Ingersoll Rand makes them, I know that much. If you have electric available, a refrigerated air dryer will work too. Might be more compact, depending on the # of CFM's you're talking about. What's the delta T you're looking for?
#3 | |
Re: Heat Exhcnager/ After CoolerQuote:
210 CFM 100 PSI I didnt know IR made them, im guessing they cost a ton though. Any links on their units? VanAir Systems sells them also, but requires 115v, i only have 12V from the compressor. Those pics i posted are from companies who include a 12v fan on their units. But the asking prices are ridiculous for those units. $900 and $2100 for the double. If i get the aftercooler, i can plumb it, and add a regular 12v radiator fan for alot less. |
What's the inlet pipe size for 210 CFM at 100 psi?
This is what I'm thinking about, but I'm not sure what the PSI rating is:
http://www.outdoorstovesupplies.com/Detail.bok?no=126 |
#6 | |
3/4" lines i dont think that will work. thats water to heat. I need air to air |
#7 | |
This company has live online chat tech support: http://www.tristatecoil.com/products.html |
another pic
#9 | |
Ha, i didnt know it was the same thing. Thanks for the link, i e-mail them. Im not sure though, it looks more for a residential home use type of thing. maybe something like this without the motor http://www.aihti.com/products/products.htm |
I would suggest contacting SMC http://www.smcusa.com/default.asp or BEKO http://www.beko.de/1.0.html?no_cache=1&L=9
#11 | |
dont see any aftercoolers listed, geared more towards plant |
Dude, If you can't find it there give up. SMC is the largest pneumatic co. in the world.
You also have some serious design problems. 200+ CFM through 3/4" pipe is causing some serious stresses and causing much of your condensate problems. Consider that the last system that I designed was based on 150 CFM max for 70K sq. ft. of manufacturing space. There were 3 compressors (one reserved) feeding a manifold into an impact seperator +++ we went 2" black iron from there. You still need condensation drops and filters @ POU.
#13 | |
| Tricks to sizing a heat pump | Danno6102 | HVAC | 1 | 06-28-2007 06:05 PM |
| heat pump help!?!!! | maxkd | HVAC | 1 | 11-10-2006 08:57 PM |
| Light fixture heat? | joasis | General Discussion | 5 | 08-26-2006 08:55 PM |
| Heat Pumps | naturenut | HVAC | 3 | 01-27-2006 02:03 AM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
