Bah Humbug!
Heat On Demand Heaters?
I need an electric "heat on demand" hot water heater.
I am going to remodel my condo bathroom this winter. The bathroom looks funky because the hot water heater is located in the bathroom and has a custom cabinet built around it. The custom cabinet looks really funky and is the first thing you see when you walk into the bathroom. I was looking into the heat on demand heaters that are pretty small. What are the benefits besides size and energy effeciency? Is there any draw backs I should be aware of? |
Administrator
Trade: Admin
Re: Heat On Demand Heaters?
Never used one myself, but I hear there real popular in Europe.
Anyways, heres some info I dug up: http://www.eere.energy.gov/consumeri...riefs/bc1.html http://www.seisco.com/ |
#3 | |
Bah Humbug!
Re: Heat On Demand Heaters?Quote:
I think the efficiency of the tankless water heaters is more fiction than fact, in real life. If you get a small one, it may not be able to keep up with the demands of a shower. But if you have a very small tank type, you may be very limited anyway.
#5 | |
Bah Humbug!
Trade: master electrician USA / France verison
yeah i see it alot in european area ( i am oringally from france) and they use both electric and gas tankless water heater but they few diffrent size you can use but bear in mind is that when you slect the size you have to figure the number of fixures, like shower , sink , tub, etc..etc.. by gallons per min or liter per min then add all the figures if you expect to use the same time , some unit will handle it pretty good some are not too well but i try to rember one company did have multi stage tankless heater , it start out with low setting first like sink facuet (tap) but when go to shower or tub even washing machine the setting on heater go up higher. some unit can draw so much juice like 1 or 2 electric stove going full speed between 6 to 18 KW of power. so it is fine for point of use but for whole house hot water heating system there is a trade off between the two.
i hope i can help you more with this one merci, marc |
I have been investigating tankless "point-of-use" water heaters for an office building. The best website I have found so far (and I have looked at several), especially for residential use, is www.controlledenergy.com.
General Contractor
Most tankless instant water heaters can provide enough water to run 2-3 fixtures at the same time. If you think about it being called tankless - it provides continuous hot water so it can run that shower for however long you want to shower. My suggestion would be to look into gas fired and not electric.
added... look into Takagi - they are the ones that I believe bought out Myson who I have used before. |
| Tricks to sizing a heat pump | Danno6102 | HVAC | 1 | 06-28-2007 06:05 PM |
| heat pump help!?!!! | maxkd | HVAC | 1 | 11-10-2006 08:57 PM |
| Heat Pumps | naturenut | HVAC | 3 | 01-27-2006 02:03 AM |
| Geothermal Heat and AC | quickfix | HVAC | 8 | 01-14-2006 09:02 AM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
