Hammering In Pipes
Old 01-20-2010, 04:58 PM   #1
Remodeling Contractor
Magic Hammer's Avatar
Hammering In Pipes
My plumber replaced a vanity sink faucet and the homeowner says he now has a water hammering noise.
Could replacing a faucet cause it?
Or is the HO lying?
Skye Builders, inc.
Decks,Sunrooms,Windows and Siding
www.skyebuilders.com
Magic Hammer is offline
Old 01-20-2010, 05:05 PM   #2
genecarp's Avatar
Re: Hammering In Pipes
I think it might be possible, if the old faucet was filled with sediment restricting the water flow, then a new faucet was installed, lots of pressure, pipe in the wall, not strapped, there is your bang, not your fault, but connected none the less, Lets see what a plumber thinks, i am just speculating GMOD
genecarp is offline
Old 01-20-2010, 05:58 PM   #3
Thom
thom's Avatar
gene could be right but it's a stretch. I think the HO noticed it because he was thinking about the new faucet. The noise has been there for years but he's ignored it. Now he hears it because he's paying attention to the new work.
Replacing a faucet will not by itself create a piping problem that wasn't there before.
I think I've heard them all in 30 years of contracting. One woman insisted it was our fault that her clothes washer stopped working (a week after we finished) because it always worked before we remodeled her house. Another insisted we screwed up the electric to her clothes dryer because it would not heat (she had turned the switch so the heat was off). A month after we finished a restaurant someone broke a large pane of glass, of course it was my fault. The amplifier died in a truck stop communication system while we were remodeling, our fault. The clock in the breakroom at a restaurant shorted out while we work working in the restaurant, our fault. It seems some people will blame the contractor for anything that goes wrong. ....then there was that cat that disappeared...........
thom is offline
Old 01-20-2010, 06:09 PM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
Try other faucets/shower controlls in the house (preferably alone) and see if it happens from that location as well.. If so, you can remove yourself from the equation.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 01-20-2010, 08:02 PM   #5
BCConstruction's Avatar
Trade: Construction
Depends if the old faucet was a qtr turn or not. The many of the older faucets were traditional type where it took 3-5 turns to close. where as you can shut these new ceramic valves down far far quicker causing water hammer.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 01-20-2010, 08:05 PM   #6
Thanks, all.
I know what you mean, Thom. I've been in the business for 35 years. Kind of tired of everything that goes wrong in the HO's life being my fault.
Skye Builders, inc.
Old 01-20-2010, 08:36 PM   #7
radimeto's Avatar
Trade: plumbing
Send a message via Skype™ to radimeto
Or is the HO lying?
CHECK YOU ARE FULLY OPEN stopcocks
This problem sometimes COMES FROM THEM
radimeto is offline
Old 01-20-2010, 08:38 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Wait for Skyhook to add his wisdom, he knows way more about plumbing than us lowly plumbers.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
skyhook (01-20-2010)
Old 01-20-2010, 09:00 PM   #9
Trade: Construction
Whats there to know! S*** flows down hill and pay days friday
The Following User Says Thank You to BCConstruction For This Useful Post:
essrmo (01-20-2010)
Old 01-20-2010, 11:03 PM   #10
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
I had a lady's dog take a nose dive into a footing trench, dog died of old age shortly after.
essrmo is offline
Old 01-21-2010, 02:29 AM   #11
BuildersII's Avatar
Trade: General
Not exactly in the same vein, but just a note on how paranoid customers can get:
We did a kitchen for EXPO Design Center a few years back, and the lady (who paid an arm and two legs for this remodel) called us up ready to go to court because her light switch we installed wasn't working. I quickly rushed over to try and fix the problem, however everything was working fine when I got there. I had to calmy explain how to use the fancy touch-sensitive switch she picked out because she had failed to read the instructions
She didn't even apologize after threatening legal action over a friggin light switch.
BuildersII is offline
Old 02-03-2010, 05:59 PM   #12
UALocal1Plumber's Avatar
Trade: Plumbing
Water hammer is caused by a valve being closed too quickly. The kinetic energy of the water flowing through the pipe is quickly transferred into the valve face, which causes a shock wave to reflect backwards, usually dispersing at the closest elbow upstream of the valve. You can see the fittings slamming around once in a while.
Usually water hammer is caused by electrically operated solenoid valves, like on a dishwasher, but flushometers, hose cocks, and yes quarter turn faucets can also cause a hammer. If no other fixtures in the house cause a hammer, check to see if the hammer manifests when closing both the hot and cold side. Then install mechanical shock arrestors on the bathroom branch piping as close as you can to the fixtures that are affected.
Keith
UALocal1Plumber is offline
Old 02-03-2010, 06:51 PM   #13
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Not a plumber but I play one occasionally on jobs sites. Two ways pipes make noise. Water hammer and lack of strapping or shimming. Water hammer issue has been dealt with here already. My guess is that its a noise that primarily occurs when hot water is drawn. There is a constant popping in the wall or ceiling somewhere that is caused by a slight expansion of the pipe. When the pipe expands, a lack of proper strapping or lack of shim where the pipe passes through studs causes the noise. Only fix is opening the wall and correcting the problem. HO has been hearing this for a while and just now thinks he has found a solution by blaming you.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 02-03-2010, 07:04 PM   #14
Trade: Plumbing
Expansion noise is a definite possibility. . . usually only if the hot water line is severely pushed against a wood framing member. Hot water is drawn through the line, the copper wants to expand, is stuck, is stuck. . . and BOOM, breaks free with a hammer noise. That should be diagnosed by drawing water from the hot water side of the faucet when the branch line has had time to cool down to room temp. Let it run until the line becomes hot, and if you get a ticking noise followed by a pop, you know the problem.
Keith
Old 02-03-2010, 08:03 PM   #15
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Or is the HO lying?
Of course it's your fault. You touched it last!
Add a little clause to your contract that addresses this. Changing plumbing can change plumbing. Unless you address this in your contract, you touched it, you own it.
Mike Finley is offline
The Following User Says Thank You to Mike Finley For This Useful Post:
Magic Hammer (02-03-2010)
Old 02-03-2010, 08:33 PM   #16
Trade: Construction
I always make the hole for the pipe far bigger than they need to be and use pipe hangers to hold the pipes secure. Aint failed yet. Like below.
Old 02-03-2010, 08:43 PM   #17
rselectric1's Avatar
BC those are the cleanest solder joints I have seen in a long time. Did you do those?
Edit-or do I need a new plumber? (Mine is licensed, union etc)
rselectric1 is offline
Old 02-03-2010, 08:50 PM   #18
Trade: Construction
Yep i was a plumber in the UK for a while. To be honest it's pretty common for plumbers to get carried away with solder. Seen it more times than i can remember. You only need the smallest amount of solder on a joint but for some reason they kill half a roll of solder on every joint
Old 02-03-2010, 09:05 PM   #19
I knew you were a plumber before in the UK. I really do read posts. Those look really nice.
Old 02-03-2010, 09:11 PM   #20
Trade: Construction
Lol cheers. The annoying thing about it though is all that work making it look nice and 99% of it gets covered up lol. Same as doing cables all nice and neat i guess.
PEX pipes or regular feedback Rennovator General Discussion 1 09-25-2009 01:02 PM
boiler pipes Boycer88 HVAC 1 02-08-2009 06:20 PM
Framing around vent and drain pipes mcnam1 Framing 6 09-05-2008 11:42 PM
Water Pipe Hammering tinner666 Plumbing 17 07-02-2007 07:49 PM
New Shower Pipes eager2start Plumbing 3 08-22-2006 05:49 PM
